A ton of pictures, sorry it has taken me so long
I am starting a new thread on this. I am sorry for not getting back asap to all the questions. I have been busy with the family and havent had much of a chance to answer back. I have also been busy with my zinc plating kit getting to all the odds and ends.
Since my last post with the pictures I have had some Pm's asking some questions so I thought it would be best to just put it all in a new thread with photos. The finish on the exhaust manafolds is por's high temp paint. In person it looks fantastic, hopefully it maintains the same look when I get some heat into them. They recommend to bead blast and just paint it on, I did that with just a foam brush after they were bead blasted, what a great product! The size of tires I am running in the photos are 275/60 15's. The pictures with just the frame are 255/60 15's. I found when I put the body on that the 255's didnt fill the wheel wells out like I had hoped so I brought them back to the tire shop and had the 275's put on. The finish on the frame is all powdercoat. I went with a semi gloss finish, the frame was sand blasted to white metal and then we used an orbital sander to smooth the outer side of the frame rails to remove the factory tooling marks and imperfections. The body has mostly all new NOS panels on it. The Truck shop in Crossville Tn. had a pr of NOS box sides that I was able to buy from them years ago. The only thing I kept from the original truck was the hood, doors and of course the cab. The rest is all NOS GM tin. Countless hours were spent correcting the factory flaws around the door and panel gaps. Although the cab was solid the guy that did the restoration on the body elected to remove the rockers and cab corners because he wanted to start from square one. We focused on correcting most all of the factory flaws on the body. We even corrected the of inside stake pockets in the box sides, along with most all of the fitting issues that we had in the front clip. The metal man that did the work cut both NOS fenders along the tops and reseamed them to get the hood/fender gaps correct. The paint has yet to get the final polish. In most of the pictures you can see a light haze in the paint, all the painter did was knock down the orange peel and buff it a little. It wont be until I get most of the reassembly finished before it is buffed to it's final shine, it is killing me a little because I am eager to get the upper chrome, the lights and everything on. Hopefully that answers the questions for now, thanks for your feedback. My goal was to build this truck so that it appeared all stock with the exception of the 2 inch drop and some of the accents on the chassis in the color grey to show some workmanship. Inside the factory looking engine and trans is far from stock also but that is another story. There is still many hours of work left before it is finished, considering that the truck was just a bare frame and no one bolt was left unturned in the restoration, it feels pretty good to be this far. Thanks again for all your help and kind feedback. Pictures.... some of these may be what you have seen before but I think most of them are new.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
Re: A ton of pictures, sorry it has taken me so long
More Photos
Some bodywork shots and Gm part numbers on the NOS panels
NOS Boxsides and misc others
Some more in the bodyshop
The wood floor in the bed. This is 1/4 Sawn Oak. The wood was hand selected and cut by a friend of mine. He is a fellow board member, I think his handle is (classicchev) His name is Darren. He is a cabinet maker by trade and makes custom wood beds.
Almost finished with the photos... here are some pic's of the progress with Eastwood Company's Tin Zinc kit that they sell. I am very impressed with it.
All of the parts were Glass bead blasted and cleaned. I have found that you can get a near chrome finish with this if you sand the pieces smooth prior to plating them. Then just buff them out with some auto sol. Very easy and fun to do. The one photo with the Back up light housing, all I did with that is glass bead blast it clean and plate it. After plating it I used a little scotch brite and gave the plating a little etch. It gives it a nice factory matte finish. With the door strikers and latches on the doors and Tailgate, I bead blasted them and spent some time smoothing the metal as best I could with scotch brite and 150 Grt. sand paper prior to plating. Then just hit them with some auto sol after the plating and thats how it looks. More pic's to come.
last one
"the other guy"
WOW!!!! thats nice, and thanks for the pix
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
motor exploder
wow, that's an amazing level of detail!! Excellent work.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Step Brother
That is very nice......
I USED to think I was anal. I am a hack compared to you attention to detail. Very nice!
#13 |
That truck is awesome!!!!
Now I have a question is it going to be a driver?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#14 |
![]() Join Date: Sep 2001
NICE!!!
I am gathering data on original BBC 1/2 ton trucks. I would love photos of the VIN/Gross Weight tag as well as SPID and/or build sheet. If possible please email photos to dtippmann@aol.com Thanks! Dan |
#15 |
![]() Join Date: Jul 2006
Beautiful Work!
#16 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Amazing work. Please keep us up to date with the progress and pics.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#18 |
yes sir, very nice indeed
If it ain't a chevy,I don't want it |
#19 |
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
#20 |
trucks72
When you get that done, send it my way. Jason
#21 |
I love these trucks in black.... just too dam dusty here
#22 |
Cowboy Up
where did u find the u-bolt mounting plates?
1971 chevy k10 *Under the Knife* Chris Cary ![]() |
#23 |
Not sure what you mean exactly with the ubolt mounting plates?
#24 |
"Taste It"
Yeah... that's not a nice truck is it!!! Sweet ride man! Looks great
B
71 Chevrolet short fleet Cheyenne air cab/tilt w buddy buckets pretty stock other wise. ![]() ![]() 2007 Silverado Crew with the MAX Pack and loaded 2007 CX-9 "Hopefully when I die.. my wife wont sell my stuff for what I said I paid for it" It's easier to ask forgiveness than it is to ask permission. ![]() |
#25 |
That is one gorgeous ride, excellent craftsmanship throughout!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() |
