Old 05-24-2009, 04:55 PM   #1
1964C10
1964C10's Avatar
Weld up the backing plate
I just finished cleaning my rearend and found out that the tabs on the backing plate that "support" the brakes (6 points) have some serious grooves worn in them probably about a 1/16 deep and I am afraid that the brake shoes will get hung up and cause bad braking problems. So I was thinking about welding up the tabs and grinding them flat. Has anyone ever attempted this? I just dont have the time to find new ones and take my rearend apart to swamp them out.
1964C10 is offline   Reply With Quote
Old 05-24-2009, 11:36 PM   #2
quadracer812
quadracer812's Avatar
Re: Weld up the backing plate
go ahead and weld them up. I do it all the time at work. most of the older vihicles backing plates are discontinued. I usely weld them and then use surfacing disk to make them smooth and then I apply some anti seize on them. as long as you get good penitration and don't warp the backing plate you should be fine
quadracer812 is offline   Reply With Quote
Old 05-25-2009, 12:32 AM   #3
1964C10
1964C10's Avatar
Thanks Qaudracer, that is exactly what I did. It worked fairly well, I didnt want to weld too much so after grinding there were still some small pockets but good enough for now. Thanks again!!
