05-24-2009, 05:26 PM | #1 |
Roll Cage
Finally making some progress again, got the back tires on it now, Put a 29x18.5 Mickey Thompson sportsman tire on. Working on installing the roll cage, ordered the main hoop from SW Race cars, the hope fits awesome in the cab, the rest of the cage we are cutting and notching all the tubing, and it is coming out really well, I have been taking my time doing all the notches and welding everything up. All I have left to do to finish the cage is install the Xbar in between the two back bars, and do the door bars. I have lexan to go in for the new back window and I am thinking I might do the side windows too. As soon as I finish welding everything up I have a buddy that's going to paint the cage a candy apple red, and he is going to paint the back part of the frame.
05-26-2009, 09:35 AM | #2 |
Sunburst C10!!!
Re: Roll Cage
cool
my junior year in high school my ag teacher said for a project he would let me put a cage in my truck if i brought the materials
Gage 1967 C10 Shortbed Stepside |
05-26-2009, 10:38 AM | #3 |
Registered Truck Offender
Re: Roll Cage
Wow, lots of nice work going on there. It only comes out 'perfect' like that when you take your time,,, looks like your doing things the right way!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
05-26-2009, 07:31 PM | #4 |
Re: Roll Cage
Thanks guys, I put the X bar in today, no joke it must have taken 6 hours to make all the cuts and notches it looks sick though, I will post a pic tomorrow. So far the whole cage is pretty much tack welded together I am going to clean everything tomorrow and finish weld it.
05-26-2009, 10:46 PM | #5 |
Sunburst C10!!!
Re: Roll Cage
are you MIGing or TIGing it
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 05-26-2009 at 10:46 PM. |
05-26-2009, 10:48 PM | #6 |
60-66 Nut
Re: Roll Cage
Looks good.
Post some pics of inside the cab if you don't mind.
05-27-2009, 07:52 AM | #7 |
Re: Roll Cage
I go to school for welding and I can mig, tig, or weld stick, but I ended up just mig welding it, I am on a tight deadline to get the cage and stuff done, and tig welding it takes forever its a slow precise process.
05-27-2009, 10:07 PM | #8 |
Re: Roll Cage
Just about finished with the Xbar
05-27-2009, 10:14 PM | #9 |
Sunburst C10!!!
Re: Roll Cage
looks good wanna come over and put mine in
05-27-2009, 10:28 PM | #10 |
Re: Roll Cage
Sure, I tried to take a picture of the welds but you couldn't really see them, I am extremly happy with the way the welding and notching has been going.
05-27-2009, 11:03 PM | #11 |
60-66 Nut
Re: Roll Cage
How have you been notching your tubes?
05-28-2009, 08:15 AM | #12 |
Re: Roll Cage
I have been cutting the angle on a nice Milwaukee cut off saw, then I have been using a grinder with these really good 36 gritt flap wheels to notch the tubing. I take my time and mark were it needs to be ground down and take a little off at a time so that the notches are tight. Most of these angles a tubing notcher willn't work.
05-28-2009, 08:19 PM | #13 |
Machinist
Re: Roll Cage
06-01-2009, 03:21 AM | #14 |
Re: Roll Cage
looks pretty dame good from turlock.did the same to my 69.sticks very well and safe.did you do the nose of the truck? and full cage the inside.its better to be safe than dead.more pics. looks *****en man.project69c10
06-01-2009, 12:09 PM | #15 |
Re: Roll Cage
Its only an 8pt cage I didn't want to go crazy with it the truck isn't that fast yet.
06-01-2009, 12:42 PM | #16 |
Sunburst C10!!!
Re: Roll Cage
im going to put an 8 point in mine but im leaving out the rear bars so it will really be a 6
06-09-2009, 12:59 PM | #17 |
Re: Roll Cage
When I re sized the picture the x bar got messed up, i have not clue why. But the truck is getting there going to put the lexan in it this weekend drove it Sunday for the first time since I have owned it.
06-09-2009, 09:21 PM | #18 |
Ready to go fast!!
Re: Roll Cage
im diggin it man!
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
06-09-2009, 09:23 PM | #19 |
Sunburst C10!!!
Re: Roll Cage
i think we need a vid
06-09-2009, 10:31 PM | #20 |
Re: Roll Cage
Its no 700hp its just a crate 350 not pushing alot of hp right now, but as soon as economy gets better that truck is getting a worked big block, and hopefully a trans brake.
06-09-2009, 10:43 PM | #21 |
Re: Roll Cage
Congrats was it like driving a new vehicle???? I havent drove mine in a year and a half so Icant imagine what it felt like.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
06-10-2009, 06:56 AM | #22 |
Re: Roll Cage
We need a profile shot.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-10-2009, 08:42 AM | #23 |
Re: Roll Cage
I am going to lower it a little more in the front this weekend or next all depends on my work schedule, All I really have to do to start driving it is, replace the ball joints and I want to change all my tie rods, and just button up some wiring bolt the bumpers back on and put the new back window in. And just give it a good tune for the street.
06-10-2009, 01:36 PM | #24 |
Sunburst C10!!!
Re: Roll Cage
ive never driven mine either
06-11-2009, 09:26 AM | #25 |
Re: Roll Cage
It was pretty cool to drive it, I was nervous but excited at the same time. But the brakes were all tight and everthing was good had a small trans leak but got that taken care of. The brakes were a little bit of a pain to bleed the truck has 10 bleeders 8 in the rear and 2 in the front, I have wilwood disk brakes on the rear, with 4 piston calipers.
