Old 05-24-2009, 09:07 PM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
suspension questions. what would you do??
I am just gathering/learning info here. with our trucks, and without lowering the truck much, IE no slamming it, I am talking an inch maybe 2 at most here but prefer to not. what would it take for the truck to handle the best? I am talking, your ideal suspension with the guidelines I have layed down. and if some how, you come up with putting a Corvette front end in it. then come up with a senerio that is the most radical and with stock components. I would do a search but I don't know enough about it to know what to search for. but I am mostly wondering What Would You Do???
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 05-24-2009, 09:31 PM   #2
Wild83C10
Wild83C10's Avatar
Re: suspentions questions. what would you do??
If you want it to handle better but don't want to lower it much then change the bushings (poly), better tires, shocks and springs.
Don't expect a corner carver, but it would be better.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 05-24-2009, 09:33 PM   #3
3r!c84
Badass
3r!c84's Avatar
start with selling your truck and buying a corvette lol=]
i say lowering it a few inch would help some
but a bigger sway bar
find a way to put a back sway bar
wider tires?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-24-2009, 10:48 PM   #4
79gmcc15
79gmcc15's Avatar
is there a way to change the lack of feeling you get from the steering wheel? like maybe a less powerful P/S pump? lol I feel like when ya drive the truck you can steer it with one finger. LOL So poly is probably the way to go huh? What kind of springs and shocks would you go with? I got the sway bar parts. but like I said. I am just learning, so don't spare the details.
RIP ELJAY
Old 05-25-2009, 02:02 AM   #5
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: suspension questions. what would you do??
You might be able to change pulleys and underdrive the ps pump.
18 to 20 inch whrels will give a bunch of road feel.
heavychevy79 is offline   Reply With Quote
Old 05-25-2009, 07:43 AM   #6
Wild83C10
Wild83C10's Avatar
Yes poly bushings are the way to go. You want a stiffer spring and a softer shock. A lowering spring is usually stiffer (higher spring rate).
There is an allen head screw on top of the box that can be used to adjust the steering feel.
turbo=
Old 05-25-2009, 11:12 AM   #7
JFP Motorsports Div
What you want to do is consider drop spindles and shackles - most of the drops spindle kits are designed to lower your truck without affecting your stock suspension; also consider polyurethane bushings as other users have mentioned (just be sure to use some sort of silicon lubricant or they will squeek like a mother..). There is a lot you can do to get your truck to handle well, another option along with the bushing upgrade is, upgrade to a bigger swaybar, maybe the 1.25" off bigger truck; as for the steering problem, you might just need a simple tune up in the suspension dept. consider tie rod ends, idler arm, etc etc... a poor and loose steering system will not respond efficiently.
hope this helps
JFP Motorsports Div is offline   Reply With Quote
Old 05-25-2009, 11:48 AM   #8
Tony_SS
Tony_SS's Avatar
Try a smaller steering wheel too... like a 13" grant or something. It'll feel less like you are driving a boat or bus.
Tony_SS is offline   Reply With Quote
Old 05-25-2009, 12:39 PM   #9
3r!c84
Badass
3r!c84's Avatar
take off the belt to the PS pump and drive it?
then you will feel the road
-00 Saturn 5spd
1/4:13:90
Old 05-26-2009, 05:58 AM   #10
D13
D13's Avatar
Whatever you try don't go manual steering. Believe me.
Perhaps a quick ratio box. But the sway bars, springs, and 2" lowering makes a big difference.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-26-2009, 06:05 AM   #11
79gmcc15
79gmcc15's Avatar
cool thanks! just added some of this stuff to my ever growing list! lol and yeah, that's a neg on the manual lol I like power steering lol
RIP ELJAY
Old 05-26-2009, 04:26 PM   #12
74 C-30
Dually Pride
74 C-30's Avatar
go with coilovers!
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
