My 67 build and I have a few questions
The suspension, steering, brakes and rear end are all new a completed brfore the truck was taken apart.
I will be doing the following before it goes back to the painter. Am I forgetting anything? 1. Cab/Bed/Radiator mounts from ECE 2. Radiator (4 row) from family friend 3. Electric fan specifically for the 67-72 from Old Air Products 4. Radiator upper and lower mounts -- factory radiator was a 3 row 5. Bolt in C-notch from CPP 6. Blazer tank kit from CPP 7. Hidden hitch from CPP 8. The truck will be bagged at some point and I recall that a large hole needs to be drilled somewhere. Can anyone tell me exactly where? I have dealt with ECE but not CPP. Is CPP gppd to deal with? Any other input on what needed to be done before it goes back to the painter?
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
Re: My 67 build and I have a few questions
Parts will be here in the next couple of days. Does anyone know what size and where the hole needs to be drilled for bagging at a later time?
Between Trucks...
This might help: http://67-72chevytrucks.com/vboard/s...d.php?t=129463
Beat it to fit, Paint it to match... ![]() |
Never Ending Projects
Chassis is looking good!
As for CPP, do a search and you will find many unhappy people, from parts not fitting to very poor customer service. Not that ECE is perfect but of the vendors I have dealt with over the years, they rank at the top of the list as one of the best. As for drilling holes for the bags, it will depend on the style of bags. Typically the lower one just screws in like a stock spring. The upper mount to the frame can depend of if they are single or dual port bags. If single port, typically you enlarge the stock mounting hole for the air fitting and add holes on each side of that for the mounting flange on the bag. Spacing won't be known until you have it in hand.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thanks guys. It looks like I will have to wait for the holes. Anything else that can be done now?
Restoration Virgin!
WOW....that frame looks great!!!
Did you get new SS fuel and brake lines??...Also, have you made sure the frame is straight??.... My was assembled before I found out differently!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 05-27-2009 at 12:21 PM. |
Sofa King Crazy!!
Many times a hidden hitch will not work with a rear mounted gas tank, might want to check into it! Great looking frame BTW.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
No I did not change the fuel or brake lines. Frame straight??? It shoould be straight -- cross members have not been removed.
when you say many times that indicates there are combinations that will work. Any recommendations? I will search and see ehat I come up with.
resident oilfield trash
Let me know what you come up with I would like to run one too
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
That frame looks good in the picts....I have dealt with CPP and had no issues...Good luck
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
I have had pretty good luck with cpp myself
#13 |
Sofa King Crazy!!
Here is the Blazer tank installed. You can see the bands are in the way of some types of hitches. The Blazer tank may affect your hitch install.
Here is another shot with an aluminum-inum tank. Hope this helps you with deciding on the hitch and tank combo.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 05-27-2009 at 04:18 PM. |
#14 |
Under Construction
Nice looking frame.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#16 |
Got all the parts ordered and both CPP and ECE assure me that the blazer tank can be used with the hidden hitch. I bought the hitch from ECE and the tank from CPP. There are many people on this board that have both so I will get the parts and figure it out. I am having a bit of buyers remorse right now but I guess that will pass as I get closer to getting back on the road.
#17 |
On the hide a hitch I had a friend that didnt use his straps and J hooks and instaed rand bolts throught his hitch and the lip of the blazer tank. Looked pretty cool
#18 |
Made some progress. Ran into a problem with the track bar and the notch (more on that in the suspension section).
