Junior Member
3sp bushings?
Does anyone make the bushings that go on the shift arms on a 3 speed trans? Will tha bushings from a Hurst shifter work?
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
I am a Referee of life.
Re: 3sp bushings?
Most BB vendors carry them.You may also be able to find them at the local APS.If no luck there go to an industrial supply house and ask for a bushing kit,may be higher but you will get a variety of bushings to cut to length made os plastic or brass,your choice.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: 3sp bushings?
I made my own using bushings purchased from Lowes. They were nylon bushings, longer than needed so I just them shorter. And I think I had to place one inside another to get the correct inside and outside diameters. It all worked fine and only cost a couple bucks.
Eventually I did find originals. Somewhere on the web and regret I can't remember where. It was a very obscure site that listed NOS held by other vendors. So I bought the bushing from someone who had to buy it from someone else. Good luck Mark |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 3sp bushings?
I've always just bought them at the GM dealer.
Junior Member
Re: 3sp bushings?
I had some leftovers from rebuilding my hurst shifter in my Mopar. They fit inside the original bushings, and the spring clips took up the slack that cotter pins didn't. Thanks for the replies.
