Old 05-25-2009, 12:28 PM   #1
bw4sale
bw4sale's Avatar
What did I do wrong?
I'm rebuilding my rear drum brakes. I got the drivers side back together and I can't even turn the wheel at all when it's jacked up. I didn't replace the shoes because they looked fine. However, I did have it completely apart. New springs and cylinders. Also, the adjusters are turned all the way in. Any ideas?
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 05-25-2009, 12:41 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: What did I do wrong?
Some questions:
Did you have trouble putting drum back on?
Did you do any adjustments afterwards?
Did it move freely right after you installed the drum?
Did you step on the brake after you installed it?
Loosen the bleed valve to see if it releases the pressure. If it does, then something is keeping the fluid from returning. Suspect a collapsed rubber hose on top of the axle (common failure).
If not then it's time to take it back out and take another look to make sure everything is in correctly.
68gmsee is offline   Reply With Quote
Old 05-25-2009, 01:10 PM   #3
bw4sale
bw4sale's Avatar
Well, since I posted this I got the other side back together and it turns fine. So I guess I did that side right.
Yes, I had a little trouble getting the drum back on. That was my first clue.
I haven't even hooked the lines back up yet, so I know it's not pressure on the cylinders.
BRENT
Old 05-25-2009, 06:38 PM   #4
bw4sale
bw4sale's Avatar
After inspecting it again, I think the e-brake cable may have been holding the shoes open. I seem to remember the drum being a little hard to get off when I pulled it. The cable is definitely stuck. No budging. So, I've got a new one on order and it all blown apart again. Hopefully, this will do it.
BRENT
Old 05-25-2009, 07:10 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Good deal.
I've heard that you can break those cables free by soaking them in diesel and/or spraying them with penetrating oil.
The recommended procedure is to use the parking brake periodically to keep it from freezing up.
Old 05-25-2009, 08:29 PM   #6
bw4sale
bw4sale's Avatar
Yeah, besides being stuck about half of the wires that make it up are broken up at the front. Time for a new one.
BRENT
