Justified!
OK, I looked thru the FAQ and searched, but di dnot find instructions on installing the rear back glass...
1. gasket on first? 2. gasket on glass first? I've never done tis before so any hints, info, tricks would be greatly appreciated..... And does the big channel on the gasket go on the window or the body? 1964 Fleetside if it makes a difference... Thanks, Chad
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
1 thing at a time is progress.
Re: How to install small rear back glass??
I keep this handy in my profile visitor messages. Hope it helps
How to install a back glass: I assume you have a new gasket. Get a piece of rope 1/4" or a little smaller diameter. I prefer nylon. Make sure it is long enough to go all the way around the glass plus a couple feet extra. Install the gasket on the glass. Tuck the rope in the grove around the outside of the gasket where the pinch weld will sit. Start and end the rope in the middle of the bottom of the glass with the extra rope on both ends. Loosely tie the rope ends together to keep them from falling out. Use some kind of non silicon lubricant and spray on the inside of the rubber. With someone else holding the glass on the outside. Start by sitting the glass down on the bottom pinch weld. If you have a 90 degree pick tool would be helpful picking at the rubber to get it over the pinch weld. Be gentle with the pick or you could tear the rubber or crack the glass. Start pulling the rope one at a time a little at a time and have the helper push down a little. It should go pretty easy until the corners. Take your time and work it slowly. Be careful and pay attention to the other end of the rope while pulling. It's possible to pull the other end of the rope into the rubber where it can't be reached. Repeat to the next corners. Your home free then after the last 2 corners. Pull the remainder of the rope a little at a time along the top until your done. Remember to have the helper bump lightly on the glass with the palm of the hand at the area you are trying pull the rope it helps a little. Good luck. The back glass is easy compared to the windshield. If you have a hard time with the back glass don't even attempt the windshield. JMHO
Alan
Philippians 2:14-16 |
The widest groove is for the glass.The round or square part of the rubber lip goes to the inside.
And you can use Dawn dish soap for the lubricant. Mike. ![]() |
Justified!
How do you keep the gasket on the glass? it keeps falling off....
You can use the narrow masking tape in strategic areas.When you're done,just peel off the excess.Put the tape on before the soap!
BTW,I've goe a 64 GMC,big window in pieces. Mike. ![]() ![]() |
