Old 05-25-2009, 04:09 PM   #1
John Pasinski
John Pasinski's Avatar
Rocker Panels / Door jambs
Can anyone point me to a "step-by-step" article on R/R of rocker panels? The tops of my door openings (where the seal runs) have holes also. I think water got in through the screw holes where the rain channel is attatched.
I've never done anything like this before, but what the heck I never welded before either then I had to teach myself at work, now I love it! So I gotta try this. BTW it's an '81 Silverado 1/2 ton. Thanks for any help at all.
John Pasinski is offline   Reply With Quote
Old 05-25-2009, 06:00 PM   #2
slash crashley
lucky knuckles
slash crashley's Avatar
Lightbulb
a quick search brought up: this. it's based on a 67 but the info should apply for the most part.
if you tackle it yourself, be sure to take pics of the process, good luck.
slash crashley is offline   Reply With Quote
Old 05-25-2009, 06:10 PM   #3
John Pasinski
Re: Rocker Panels / Door jambs
Thank you slash. Although I gotta say it looks pretty intimidating. I better line up a ride to work for a few days as I think the first one may take me more than a weekend.
Old 05-25-2009, 06:26 PM   #4
slash crashley
lucky knuckles
Lightbulb as luck would have it.
...i'm going to maitland autobody tomorrow for a 4 wheel alignment (my truck's leaning left as the rear axle has shifted slightly) i'll see if he can give me a ball park on the cost for remove and replace rockers. it's gotta be pretty routine.
i've got some nasty snaps from a PO's tonneau cover and some ghastly riveted aluminum trim i'd like smoothed out. i'll letcha know the numbers and the service level.
whereabouts in the city murderful you at? i'm downtown.
Old 05-26-2009, 02:46 AM   #5
John Pasinski
We live over near Seaworld in Willamsburg. I have of course done searches online for rocker repair. But so far, found nothing like the article you've sent. I'll keep searching for more detailed step by step. I'm trying to find an article that will be helpful, and allow me to attempt this myself.
Old 05-26-2009, 06:23 AM   #6
James McClure
One shot, one kill.
John, I did mine and have some pics I can send you of whats involved. It is by no means an easy chore. Mine was a horror story the rust was so bad as you will see. The pics won't fit here but you can resize them and post them if you like. If you order rockers from LMC don't bother with the backing plates or panels, they are crap, just make your own from 1
\16 stock sheet metal. My e-mail is jmcclur2@nycap.rr.com. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 05-26-2009, 07:33 AM   #7
sperz1
sperz1's Avatar
I was in the same position as you as far as welding experience goes when I replaced the pans and rockers on my old VW. Do the research, buy a welder, practice a bit, then jump right in. It's a great way to learn.
sperz1 is offline   Reply With Quote
Old 05-26-2009, 06:45 PM   #8
John Pasinski
After some more digging around, I found the "footwell?" is rotting out also. That's how the water is getting in. I had to toss my jute, & carpet cause it was wet & rotted. So are those spot welded also? LMC sells them along with the other patch stuff.
Old 05-26-2009, 08:07 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
This is some pics from a customer installing our 5 piece cab repair kit.
http://forum.73-87chevytrucks.com/sm...p?topic=5661.0
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-27-2009, 02:52 AM   #10
John Pasinski
Many thanks to you Chris for that step by step. I will read, & re-read before I start anything. I guess this isn't your average "get it done on a weekend job". I'm also trying to get an 80 gallon compressor as mine is in worse shape than me. I've had it 30 years, and I'm tired of fixin' & rebuilding it. I appreciate everyone's help and great suggestions.
Old 05-28-2009, 01:41 PM   #11
Captkaos
Captkaos's Avatar
No problem.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
