05-25-2009, 04:24 PM | #1 |
exhaust leak
It looks like I have some air escaping from the passengers side exhaust manifold where it connects to the exhaust pipe. I plan on replacing all the exhaust manifold gaskets this week on both sides. Would this cause my truck to not have a lot of power? Especially uphill.
05-25-2009, 04:33 PM | #2 |
Just here to tinker
Re: exhaust leak
This won't cause power loss, but will cause you to be very annoyed. I can't stand exhaust leaks.
As for power loss, you said that your carb needs to be rebuilt. What kind is it? Also what is the rest of your engine set-up and when was the last time the timing was checked and/or tune-up completed?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
05-25-2009, 05:24 PM | #3 |
Re: exhaust leak
Looks like I spoke too soon. I went back out and adjusted timing some more and now it has power. I was going by the white timing mark but this time I did it by ear and there is a big difference. Now it goes if I hit the gas and no problems going uphill. Still need to work out the brake problem in my other thread.
Oh and by the way the truck has a rebuilt 283 v8. New fuel pump, new distributer, new plugs and wires but I had to clean them today, new valve covers and gaskets, new intake manifold and gaskets and new air cleaner. Upgraded to a 4 barrel rochester quadrajet a friend gave me but needs to be rebuilt most likely. I have no idea how to adjust carbs so hopefully I can find some info on line on how to do that. It seems to be sticking when I try to start it sometimes but once it warms up its fine. I rebuilt the old two barrel I had so I should be able to do this one until I can afford a edelbrock. |
