![]() Join Date: Jan 2009
auto crossmembers
Has anyone used the auto transmission crossmembers that ECE or GMC Pauls sales? Pros/Cons Trying to decide if i want to buy one of those, or try and find an original.My truck was a three speed and doing an auto conversion.Thanks
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
Re: auto crossmembers
I did this already I converted my truck from 3spd to automatic....I used the one from CPP...Fits and looks perfect...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
dazed and confused
im intersted in this also. i would like to run the exhaust over it and through the crossmember.
members met: redbaron69, billsbowtie,nc67 |
I bought one from GMC Pauls and it looks good. However, I tried to fit it in there and could get very few of the holes to line up. Perhaps this is what is expected and I need to redrill a few of the holes.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Can you weld at all ? It's dead easy to make a simple crossmember like that and you will end of with significant cash left in your pocket to spend on other parts of the truck.
tx firefighter, not a bad idea! it never hurts to do something yourself and save some cash. anybody got some pics of what they have done?
Two pieces of angle iron to bolt to the frame on each end and a piece of thick wall tubing between them with a little perch welded onto the center of it for the mount to bolt to. It should be an easy couple of hour job if you have done that kind of thing before.
i probally got the materials laying around the shop and welding is not a problem. thanks tx firefighter sometimes we forget to think "outside the box"
