Old 05-25-2009, 09:24 PM   #1
jamie72
jamie72's Avatar
steering wheels f/s
[IMG]//http://www.seidata.com/~rmosley/for%20sale/2009_0524springfieldspring0041.JPG[/IMG]
3 spoke wheel- 180.00 shipped
red 4 spoke- 50.00 shipped
black 4spoke 35.00 shipped
last one- 25.00 shipped
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-25-2009, 09:26 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: steering wheels f/s
your pictures didn't post.....
Hart_Rod is offline   Reply With Quote
Old 05-25-2009, 09:31 PM   #3
jamie72
jamie72's Avatar
yea i see and i can`t edit... sorry..i`ll have a mod delete i`ll repost tomorrow..
jamie72
member #807
www.antlertalk.com
Old 05-25-2009, 09:35 PM   #4
Shane
Shane's Avatar
... let see if this works
Shane is offline   Reply With Quote
Old 05-26-2009, 03:05 PM   #5
jamie72
jamie72's Avatar
cool...thanks
jamie72
member #807
www.antlertalk.com
Old 05-26-2009, 08:11 PM   #6
nds1968
nds1968's Avatar
More info on the black three spoke wheel please. What does it include and is it new? Does the side view of the hand grip show metal? Was it bolted to a factory column? Thanks
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 05-26-2009, 08:43 PM   #7
jamie72
jamie72's Avatar
not new but very nice shape,the horn button is new,it includes everything you see,new button,the mouting collet,the horn spring,does need a couple screws, and yes you see a metal ring around the edge, it has one very small nick in the rubber,other than that great shape.
was told a early vette-camaro wheel
jamie72
member #807
www.antlertalk.com
Old 05-26-2009, 09:56 PM   #8
nds1968
nds1968's Avatar
Thanks but I am going to hold out right now for one without the metal showing. I know corvette and camaro wheels where deep. That one your selling doesn't look that deep but It's hard to tell. Other than the metal showing that's the look and style I may go with. Thanks
Nate
Old 05-26-2009, 10:08 PM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Yes, your 3 spoke wheel is a Chevelle, Camaro, and Corvette wheel, no doubt about with owning a Chevelle, and over the years owning old vettes. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-27-2009, 06:00 AM   #10
^ X2 ^
There are simular repros.But,factory wheels had the ring exposed on the edge.There are wooden wheels that go for big big bucks.
That red 4-spoke is an Olds?The same center would work on that as what`s on the 3-spoke,right?I sure am tempted...
Old 05-27-2009, 09:38 AM   #11
71blksuper4x4
SWB 4x4 Collector
Tim, I believe that your correct and that the same horn button would work on those 4 spokes as well.
TREVOR
Old 05-27-2009, 03:36 PM   #12
jamie72
jamie72's Avatar
^ X2 ^
yep same center would work...
jamie72
member #807
www.antlertalk.com
Old 05-27-2009, 03:59 PM   #13
nds1968
nds1968's Avatar
^ X2 ^
The Truck Shop had them with or without the ring exposed and the depth of them seemed shallower than factory wheels. They had chevelle hubs on them to fit C10 trucks. Is there a measurement difference or was I going crazy from the heat at Carlisle this year?
Nate
Old 05-28-2009, 07:39 AM   #14
70GMCer
70GMCer's Avatar
I'm using the 3 spoke custom grip wheel & I've been told that the mounting hubs comes in 2 different diameters. Both fit any early GM column. However, the one on mine is 4" wide at the base and makes that extend about 1/4" wider onto the column. It extends out on the sides.
Someone told me sometime back that the Corvette hubs were wider than the Chevelle & Camaro ones. Don't know how true that is, but would like to find a narrow one.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-28-2009, 08:55 AM   #15
71blksuper4x4
SWB 4x4 Collector
U need a reproduction 1967-68 camaro hub. You can find them at Classic Enterprises and others, any place that sells Camaro or Chevelle parts. The 1969 hub is the wider one you have.
TREVOR
Old 05-30-2009, 10:02 AM   #16
jamie72
jamie72's Avatar
ttt
jamie72
member #807
www.antlertalk.com
Old 06-01-2009, 09:48 PM   #17
bowtiedriver2
bowtiedriver2's Avatar
I may be interested in the red wheel. what diameter is the wheel and do you know what is needed to adapt to a 3-on-the-tree column?
'69 LWB Stepside, 350 with mild mods, and 3 speed on the floor
Intentions...383 sbc (in assembly stage), trans is still not a definate (3, 5, or 6 speed?), 3/5 drop, power disc brake conversion...then some body work.
bowtiedriver2 is offline   Reply With Quote
Old 06-02-2009, 06:32 PM   #18
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
If the rubber on the Comfort Grip three spoke wheel is not sticky I'll take it. Shipping to 71457?
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
www.louisianaclassictruckclub.com
65StreetCruiser is offline   Reply With Quote
Old 06-02-2009, 06:39 PM   #19
jamie72
jamie72's Avatar
i would think the same as any other chevy coulm,they have the same shaft spine.. just buy the after market hub..the wheel is 14.5 outside -outside.
jamie72
member #807
www.antlertalk.com
Old 06-03-2009, 10:45 PM   #20
65StreetCruiser
It Is What It Is
jamie72, I'm gonna have to pass on the steering wheel. The other,better half said that the money is not right at the moment.
Kevin
Old 06-04-2009, 04:29 PM   #21
jamie72
jamie72's Avatar
no prolebm.. i know how it is...
jamie72
member #807
www.antlertalk.com
Old 06-06-2009, 10:10 AM   #22
jamie72
jamie72's Avatar
last bump.
jamie72
member #807
www.antlertalk.com
Old 06-07-2009, 09:26 PM   #23
bowtiedriver2
what is the dameter of the black three spoke? I am sure I will be buying either the black three spoke or the red one.
Old 06-07-2009, 09:30 PM   #24
jamie72
jamie72's Avatar
15 inch outside to outside....
jamie72
member #807
www.antlertalk.com
