Old 05-25-2009, 11:10 PM   #1
jritt72
jritt72's Avatar
Gas lines
I am moving the gas tank to the rear. I have a tank for 72 blazer, and I want stainless gas lines from motor to tank. Any help on where to get them.
Jeff
Jbritt72
jritt72 is offline   Reply With Quote
Old 05-26-2009, 12:58 AM   #2
UltraBlue71
UltraBlue71's Avatar
Re: Gas lines
I took a 5 ft piece of 5/16 brake line and ran it inside the frame rail, I used spiral wrap where it might rub. I secured it with adel clamps to the frame right next to the brake lines. I went from the tank to that line with rubber hose and hooked into the existing cab line with rubber fuel hose too. I capped off all the vents on the tank except for the filler neck vent, works like a champ! Make sure to get a vented cap or she'll really build up a vaccum!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 05-26-2009, 05:28 AM   #3
cdowns
cdowns's Avatar
Re: Gas lines
go to auto parts or boat supply store or plumbing supply and ask if they carry 3/8stainless tubing// or summit jegs or speedway motors
Old 05-26-2009, 10:41 AM   #4
Shane
Shane's Avatar
Re: Gas lines
http://store.summitracing.com/partde...5&autoview=sku
Shane is offline   Reply With Quote
Old 05-26-2009, 04:20 PM   #5
Sammy
Re: Gas lines
Any supplier of aircon/ heating Co. has rolls of stainless 3/8 tubbing. Which is what I used.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-26-2009, 11:57 PM   #6
jritt72
jritt72's Avatar
Re: Gas lines
thanks for all the input guys. I'll start a build thread soon, cause i know.....
Jbritt72
