05-26-2009, 10:48 AM | #1 |
sleeved bags on rear links
I'm bagging my truck and I have enough space to run sleeved bags in the rear on the arms where the spring use to be.. I was wondering if there would pros and cons to this set up and if any one else has done this?? Also is there a website to get the specs on firestone air bags?? Thx in advance..
1969 Chevy C-10 350/700r4 |
05-26-2009, 11:05 AM | #2 |
Re: sleeved bags on rear links
It's really best to avoid putting sleeve bags on a bar. They cannot handle the misalignment that comes with it. And you need to mount them close to the axle, because they can't handle too much leverage. I have plans on a way to do it, but it requires shackles and extra link bars to keep the bag straight through the entire travel of the suspension. Simply putting them on a link bar will stress them too much. They should be mounted directly to the axle.
If you can find it cheaper, I can fix it! |
05-26-2009, 04:48 PM | #3 |
Dont know if this is what you were looking for or not....http://www.firestoneindustrial.com/n...s_sleeve.shtml
Are you looking to get more lift from a sleeve? |
05-26-2009, 05:46 PM | #4 |
thats the one thx u layframe and twisted
05-26-2009, 05:47 PM | #5 |
Ya sleeve bags are the best for bag over axle and bag behind axle...
Adam M STX Designs Motorcycles | Choppers | Hotrods |
05-26-2009, 11:35 PM | #6 |
Im not trying to be negative and really apreciate the advise and responses but whats the diffrence between behind the axle and in front of the axle? I was lookinjg at some of the 18 wheelers at work and noticed that they have them in front and they are sleved and some are Double Convoluted bags...
05-27-2009, 01:24 AM | #7 |
There is no difference if they are mounted to a bracket that is welded to the axle. It reacts and rides the same, it just depends on what kind of space you have to put the bags.
05-27-2009, 11:08 AM | #8 |
f9000's really dont have the load ability to handle being mounted in a ratio.
05-27-2009, 12:02 PM | #9 | |
Big trucks most likely have entirely different weight ranges for the size of the bags they have installed. I know we use some sleeve type bags on some of our automated palletizing equipment & dbl convoluted bags in other areas (freakin' huge dbl convoluted bags @ that).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-27-2009 at 12:04 PM. |
05-27-2009, 01:08 PM | #10 |
look at the set up im working on ...
