Old 05-26-2009, 11:19 AM   #1
ont_guy_38
ont_guy_38's Avatar
Lowering shackles
Found a set on ebay i was going to bid on but decided to look at the truck first and I,m wonder how on earth do you get longer shackles when there isnt even enough room to stick your fingers inbetween the box and shackle
ont_guy_38 is offline   Reply With Quote
Old 05-26-2009, 11:21 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Lowering shackles
you will have to notch out the cross member
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-26-2009, 11:25 AM   #3
Turbo85GMC
Turbo85GMC's Avatar
What he said.
I've heard that it depends on the length of the springs. IIRC, the longer ones clear the cross member. The longer ones might be for the HD option?
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 05-27-2009, 11:53 AM   #4
harnalien
TruckincrazY
harnalien's Avatar
Do you still have to notch the crossmember if you use hangers?
harnalien is offline   Reply With Quote
Old 05-27-2009, 02:47 PM   #5
flamingbig10
6.0 powered square
the lower hangers replace the hangers closest to the gas tank
Aaron
Old 05-27-2009, 03:25 PM   #6
3r!c84
Badass
3r!c84's Avatar
any one have any pics of the cut notch with shackles and hangers?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-27-2009, 04:09 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
I usually take out all but the last 3/4" at the bottom of the cross piece (up against the bed floor). The notch would need to be as long as the spring assembly and the bolt is, so that there is clearance on both ends of the notch. After cutting a notch into the corsspiece and leaving the last 3/4 inch of metal, I use a piece channel iron or a square tubing cut in half to bolster up the cross pice, so that I do not loose that strength in it. I then drill three bolt holes through the cross piece and the tubing and bolt it together making the notch stronger.
piecesparts is offline   Reply With Quote
Old 05-27-2009, 05:12 PM   #8
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I must have the long springs because I didn't have to notch mine. I planned on it but didn't need to. I will hit my diff on the bed floor before the shackle hits the crossmember.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 05-28-2009, 03:02 PM   #9
3r!c84
Badass
3r!c84's Avatar
why did gm make 2diff. sizes ?
-00 Saturn 5spd
1/4:13:90
