![]() Join Date: Jul 2006
Gauges or no?
How many of you use gauges for your bags? How do you have them configured? Are they really needed?
Re: Gauges or no?
Yes, they are needed. How would you determine the correct PSI setting in which to set the alignment otherwise?
Re: Gauges or no?
I only use my gauges to know where my fenders are at in relation to my tires.
so when I normally drive I just bump the up switch twice and roll like that. mine are configured as one gauge needle per bag. if you have a four way system you need four gauge needles, one for each bag. If you have a 2 way system your fine with two gauge needles. I say gauge needles since gauges do come in dual needles per gauge. They are needed to insure you dont smoke a fender, other than that I dont really use them. just a FYI but your going to want to use 1/8 line to run them to help with pressure fluctuations. good luck shane you can use height sensors like ART and accuair now use. PSI really does mean nothing in the long run since it isnt proportional to height in anyway. Im sure you knew this with you vast knowledge, just wanted to refresh. ![]() and do you even have a bagged vehicle? just wondering |
Re: Gauges or no?
I use 2 dual needles and a single. All four corners and the tank. Monitor the tank to make sure the pressure guage shuts off the compressors. The front guage is there to make sure I don't chunk the fenders and the rear is mainly there for show. For the price of 3 guages and some eigth line, I see no reason not to have guages.
Re: Gauges or no?
The original poster did not ask about height sensors, he asked about gauges, thus my reply.
So you're saying that bag pressure has nothing to do with bag height? ![]() |
#6 | |
Re: Gauges or no?
the only time I know exactly where my truck is at is at 0psi(laid) or 200psi(locked). so there is no correlation to bag height and psi besides knowing Im off the ground and approximately this far from terrorizing a fender. which is why the height sensors are really cool. so you have a bagged ride or what? |
Re: Gauges or no?
So if you don't use your gauges, then how do you know you it requires 15-20 more PSI to achieve the same ride height?
Re: Gauges or no?
This argument is exactly why I posed the question...
Re: Gauges or no?
WTB this ad
Re: Gauges or no?
My wifes 54 has got gauges...I just got off the phone with Dustin at Accuair and I've got the parts to get us hooked up with a management system on the way. So we'll be ditching the gauges!
Re: Gauges or no?
#12 | |
Re: Gauges or no?
Just drop it...that is not relevant either way. I don't currently own a straight axle 4x4......doesn't mean I don't know them inside out. Arguing for the sake of having the last word is against the rules....plain and simple.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#13 |
Re: Gauges or no?
it is simple with no guages, you just air it up, start driving, dump it til it drags and tap the fill once, simple.........
#14 | |
Resistance is Futile
Re: Gauges or no?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#15 |
senior member
Re: Gauges or no?
im with shane on this one with what u guys are saying u can basically tell how much air a tire has as well? just hold the air chuck on there till it looks good and giver? never mind if its over/underinflated?
69 GMC bagged |
#16 |
Happy to be here
![]() Join Date: Mar 2000
Re: Gauges or no?
Guys lets keep this civil, or it gets locked.
Back to the OP's question, I would say that the "majority" of the trucks that are bagged run some sort of gauge. I know that the basic single/dual needle gauges are not that accurate, but they do give you something to go on. As Shane points out they are a basic point of reference for setting a safe ride height, max and min height as well. Can you do a basic system without gauges? Yes, but I wouldn't recommend it.
#17 |
Re: Gauges or no?
From my experience, I would say gauges are a good idea. After I installed my bags, I just set up a manual fill for both front and rear (while waiting for parts) and drove it around to get used to ride height and it was a PITA because I was getting out to keep checking heights.
I agree that the gauges aren't the most accurate, and they vary with what/who is in the truck, they vary with temperatures and can flucuate while driving, but they at least give you the "baseline" information. I'm going with three gauges: 2 dual needle and one single. |
#18 | |
Re: Gauges or no?
you seriously think thats a good comparison? a 6 or 7 inch dia. bag 4-6 inches tall has much more expansion room than a tire and less volume of air. |
#19 |
Re: Gauges or no?
so you're saying you do use your gauges then ... gotcha.
#20 |
Re: Gauges or no?
#21 |
Seņor Member
Re: Gauges or no?
If you're going to argue just for the hell of it, at least try and be consistent. Someone, please lock this thread. The OP got his question answered and many of us got a good idea which board users need to go into the ignore list.
