______________
![]() Join Date: Sep 2006
Pics of your 18" wheels/ tires?
I've decided to go with 18's on my shop truck and would like to see what you're running - tire size specifically.
I can't go with a lower profile and want to stay above a 40/45 series tire. Let me see what you've got. |
______________
Re: Pics of your 18" wheels/ tires?
I think I'm leaning towards a 255/55/18....
I don't have any pics, because I haven't done it yet. i scored some 18x9's real cheap, and though the 255/55 looks to acceptable in the width department, ive got some 255/50s on my last project and and worried that the 55s will leave the rim too little just-in-case curb room. 1010tires.com has a pretty awesome calculator for measurements and rotational speed differences.
I'll follow this one with ya. |
I have 255-50-18 in the front mounted on Coys C5 18x8
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
![]() Join Date: Oct 2005
18's on mine.
18x9.5 out back & 8's up front w/ 275/55 & 255/50. I like a little bigger diameter wheel and really like a little more tire sidewall.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
18's on this one as well......can't remember exact specs.
______________
Sacto Jim, how much is the blue truck lowered and how? thats the stance i want for my driver project. thanks, Andy
you gotta be kiddin!
![]() Join Date: May 2009
They both look great. I agree that more side wall is better. The 18's are the ticket. Now I know what to be lookin for.
It ain't easy being greasy! |
chevy truck fan
sactojim,
can you give us your backspacing if you know it??? thanks!! beautiful truck too!! |
#11 | ||
Thanks!........back spacing is 4" up front and 4.5" out back.
TILT COLUMN GURU
![]() Join Date: Dec 2006
295/45X18 Rear, 255/45X18 Front.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
#13 |
Here a few of mine.Coys 18x8 255 55 18 all 4 corners.
#14 |
______________
Jackpot! This is the exact setup I'll be running up front.
Thank you for the pics! This helps me a lot. |
#15 |
To The Levy
285/60.18 on a set of 8 luggers , made by center line, I had to lift front a tad, due to tire and wheel combo, fenders rubbed tires upon hitting big bumps, I went with a set of rancho lifting coils, I got three inch lift and straightened out the rake it had, now its level .........
#16 |
How much drop do you have, if any?
#17 |
67-72 Addict!
Those Coys are sharp!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#18 |
#19 |
Here my 18' 8s and 10s.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#20 |
______________
Alright, for some reason this idea looked better in my head than in person.
15's replaced with 18's: 255/55/18 up front and 275/55/18 in the rear. Before and after pics below. Extra points awarded for trying something different? You saw it here first! Nissan Titan/ Armada 18"x8" wheels on a 67-72. |
#21 |
That looks good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#22 |
It's alsways something.....
![]() Join Date: Nov 2008
"Alright, for some reason this idea looked better in my head than in person."
Well,IMO no larger diameter wheel looks good with the truck at stock height. How about someone do a photoshop 5/7 drop on the new pic and see what it looks like... |
#23 |
______________
Photoshop work courtesy of SIK6FOR.
If I weren't having to sell this truck, this is what it would probably look like - |
#24 |
what brand of tires did you go with?
#25 |
______________
