Old 05-26-2009, 04:32 PM   #1
scsindust
Difference in NP208 & NP241
I am working on my 89 3/4 Suburban. It currently has a th400 mated to a NP241. I have a rebuilt 700R4 that I wanted to put into it, which is mated to a NP208. I know the 241 has an electric speedo, as the 208 is mechanical. Is there any other differences that would make me want to keep the 241? Also, I heard the 241 is a direct swap from a 208. Is this true? Thanks for all your help!
Jamie
Play truck / kid hauler - 1989 V2500 Burb 4x4, 350, 700R4, 4" lift, headers, elec fans, the normal mods. Getting ready for the LS1 swap!!
scsindust is offline   Reply With Quote
Old 05-26-2009, 08:10 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Difference in NP208 & NP241
Try and see how many splines are on both and if they are the same you should be good to go.
tvblazer78 is offline   Reply With Quote
Old 05-26-2009, 09:39 PM   #3
WarBeard
WarBeard's Avatar
4lo on the 241 is 2.72:1
2.61 in the 208
241 has a better oiling system and will keep cooler
241 is the best of the aluminum t-cases IMO.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 05-26-2009, 09:41 PM   #4
WarBeard
WarBeard's Avatar
also id like to add that the 700r4 has a lower first gear if im not mistakin
that combined with the 241 will give you a very nice crawl ratio!
Old 05-26-2009, 09:45 PM   #5
scsindust
Thanks! I appreciate the input. I don't plan on doing hard wheeling or crawling, but just some weekend fun driving through trails, etc. Hopefully the 241 will swap straight over to the 700.
Jamie
Old 05-27-2009, 08:43 AM   #6
Jonboy
Slots go on anything!
the 241 should swap over fine. They came in the 90 & 91 burbs, with a 700R4.
Old 05-27-2009, 09:47 AM   #7
scsindust
Well on that note, if anyone wants a NP208,
Jamie
Old 05-27-2009, 09:52 AM   #8
scsindust
Does the 241 use ATF or gear oil??
Jamie
Old 05-27-2009, 12:55 PM   #9
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Atf
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-27-2009, 01:00 PM   #10
tvblazer78
Low & Fast!
tvblazer78's Avatar
Originally Posted by scsindust View Post
Well on that note,
Sorry man you can not sell stuff if you are not a member. So become one and you can.
Thanks,
Trav
Old 05-27-2009, 01:04 PM   #11
scsindust
I did register. Doesn't that make me a member? Is there more I have to do? You delete that post if you want about the 208.
Jamie
Old 05-27-2009, 01:08 PM   #12
tvblazer78
Low & Fast!
tvblazer78's Avatar
Let me try this again, you are a member but not a paying one. Here is the linke to support the board.
http://www.67-72chevytrucks.com/vboard/payments.php
Old 05-27-2009, 01:24 PM   #13
scsindust
Gottcha. Will do.
Jamie
Old 05-27-2009, 01:30 PM   #14
tvblazer78
Low & Fast!
tvblazer78's Avatar
Gottcha. Will do.
Thank you sir!
Old 06-30-2009, 08:52 PM   #15
scsindust
I just came across some info that this swap might not work. I saw that NP241 on TH400s have a larger spline than those of 700R4s. So if my 241 wont mate up to the th400, can I use the parts from my NP208 that is currently on my to-be-installed 700r4 and make the 241 work? I guess my only real hangup on the 241 is that it has an elec speedo, which I would need to make it work in the truck. What would be my options if this swap doesn't work as planned? Can I use the 208? How could i make my speedo work with it?
Jamie
