Old 05-26-2009, 04:51 PM   #1
kamby
kamby's Avatar
Carb Welch Plug leak on 1972 GMC
Hello,
I have a 1972 GMC Pickup, its got a 2 barrel carb with the fuel filter in the carb. One day i was driving home and smelt fuel at idle. I opened the hood and noticed some seeping out of the welch plug on the carb right where the fuel line and filter enter into the carb. Is this something easy to fix or do i have to replace/rebuild the carb? If need be i can get a picture taken.
It has the sb 350 and probably the quadrajunk or rochester on it.
Jason
Give a man a fish and he will eat for a day, teach a man to fish and he will spend all day in his boat fishing and drinking beer.
kamby is offline   Reply With Quote
Old 05-26-2009, 06:06 PM   #2
425HP409
425hp409
425HP409's Avatar
Smile Re: Carb Welch Plug leak on 1972 GMC
You need to clean off the plug, scuff it up a little bit, and then apply some two part epoxy like JB Weld to it. Cover the plug and the surrounding carburetor area with the epoxy. If done correctly, it will never leak again.
Charles
425HP409 is offline   Reply With Quote
Old 05-26-2009, 07:01 PM   #3
kamby
kamby's Avatar
Thanks for the reply, and tip. I'll probably do that. I wanna put a new carb on this thing just not right now. Wont the gas eat the jb weld stuff.
Jason
Old 05-26-2009, 07:23 PM   #4
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
tap it gently with a ball peen hammer...GENTLY! It will flatten the solder and stop the leak, and you won't have a wad of pucky on the front of your carb.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
