Old 05-27-2009, 12:19 AM   #1
72truckman
72truckman's Avatar
2005 5.3 Fuel System
Regarding my fual system, what do i need to buy if i have an in tank pump that can more than handle a 5.3 needs. It is a return-less 5.3, but i've heard you still need a regulator like this one(which is also a filter):http://shop.corvettecentral.com/C5-1...-p6021564.html
Also, what kind of line do i need to use? is there rubber line capable of withstanding 58PSI or should i go with braided?
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 05-27-2009, 04:59 AM   #2
vtblazer
vtblazer's Avatar
Re: 2005 5.3 Fuel System
Any rubber line rated for fuel injection will be braided internally but I'd still check the PSI rating of it before you buy any.
Sorry, no help to ya on the 5.3 stuff.
vtblazer is offline   Reply With Quote
Old 05-27-2009, 06:53 AM   #3
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Use 3/8" steel rigid line as mush as possible. The fuel injection hose is expensive!
FuelCellGuy is offline   Reply With Quote
Old 06-02-2009, 01:13 AM   #4
junkman
I just got through plumbing mine, I used dorman hard plastic line, with quick connect fittings like factory. I am using an inline pump, ran rubber from the tank to the pump, plastic from the pump to the vette filter/regular, rubber return, plastic up to the rails. Was about the cheapest setup I found.
junkman is offline   Reply With Quote
Old 06-02-2009, 11:55 AM   #5
72truckman
72truckman's Avatar
Thanks junkman! where did you find that plastic tubing? also, what quick connect did you use to mate the fl line to the fuel rail?
Work in Progress
Old 06-03-2009, 10:54 PM   #6
wheatlysk5
here ya go
http://www.jegs.com/i/Aeromotive/027/15118/10002/-1
wheatlysk5 is offline   Reply With Quote
Old 06-03-2009, 11:09 PM   #7
wheatlysk5
you can also use aliminum tube and an fittings. its easy to bend and cheap.
3/8 fuel line- http://www.jegs.com/i/JEGS/555/15100/10002/-1
compression fittings- http://www.jegs.com/i/Earl%26%23039%...65106/10002/-1
pay no attention to that 50 psi max bull stuff
Old 06-04-2009, 09:32 PM   #8
72truckman
72truckman's Avatar
Thanks for you help WHEATLYSK5! I have never used the AN fitting and such, do i just need a flare tool for that aluminum line?
Work in Progress
Old 06-05-2009, 12:29 AM   #9
sandking
.....I am working on it.....
sandking's Avatar
I got all steel braid lines and AN fittins for my 5.3. It goes from the tank to an inline filter, then to the inline pump. From there it goes to the inline pressure regulator (with a return back to the tank) then to the fuel rails.
View my build thread HERE
sandking is offline   Reply With Quote
Old 06-06-2009, 10:43 PM   #10
clinebarger
I used a 99 corvette fuel filter on my suburban has a built in regulater.
clinebarger is offline   Reply With Quote
