12-31-2002, 06:26 PM | #1 |
urban fourwheelin
2 peice rims
what years are good to replace two piece rims? When did they start making them one piece? will the back spacing be the same?
I'm asking for my dad becuase he has two piece rims on his 76 3/4 suburban. I'd like to keep it original looking with gm rims, any help would be much appreicated. red72 My dad wants to but some aftermarket rims, but the money we would spend on thoughs rigth now, would be better spent on other areas of the truck.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
12-31-2002, 06:41 PM | #2 |
My other Love
Go to the bone yard and find some 16's off any 73-87's or any older Dodge. If worse comes to worse , you might have to use 16.5's. Get rid of those damn split rims, not worth the risk of losing your head over them. I suggest you chuck em in the forest.
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
12-31-2002, 06:46 PM | #3 |
urban fourwheelin
dodge and chevy have the same bolt pattern? We allready have 16.5. they are really hard to find tires for. I was gonna weld them together and make bar stools
12-31-2002, 11:21 PM | #4 |
Born Psycho
ford or dodge wheels will fit a chevy but not the other way around. newer ford wheels won't work, they don't center off the lug nuts. they center off the hub and use flat lug nuts instead of tapered. another of ford's "better ideas",LOL .
unless you're running bigger tires, 16.5s are an expensive thing to find. 33s on up are still fairly common but smaller sizes are tough to get. if you have a pick-n-pull type yard near you, 16s are common as water.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-31-2002, 11:27 PM | #5 | |
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
12-31-2002, 11:32 PM | #6 |
Born Psycho
and the "7" lug heavy half/light 3/4 ton. like one of my co-workers says,"FORD" at least they circled the problem,LOL.:p
01-01-2003, 01:05 AM | #7 |
Cantankerous Geezer
The thing to do is to measure the setback of what you are running. That's the distance from the back of the rim to the face the brake drum mates to. I use a framing square (it's the right length) and a tape measure. Put the square across the outer flange of the wheel without resting on the tire.
Next, go to the salvage yard. Tell them you're looking for an 8 bolt GM rim. I know they used the same rim at least into the mid 90's, I think they still have the same bolt pattern and center (or hub). It is important to get the proper hub size, that is where your shear load is transfered from the truck to the tire. 16" is the common size for the 3/4 ton wheels and the tires are easy to get.
Fred There is no such thing as too much cam...just not enough engine. |
01-01-2003, 11:42 AM | #8 |
16.5's dodge rims
I had the same problem and couldn't find 16 or 17's so I settled for 16.5's from a late 70's Dodge van with same bolt pattern. I figured anything was better than those split rims that came with the truck. A local tire dealer had an employee get killed in the 1980's trying to put a tire on one of them. In PA they are outlawed now. I got these dodge rims for 5 bucks a piece in my local yard as they rolled that van in the gates.
Dave Benamati Hughesville, PA USA |
01-01-2003, 12:04 PM | #9 |
16.5's dodge rims
Pic?
01-01-2003, 05:15 PM | #10 |
Registered Abuser
Anybody got any pics of the split rims, so I can avoid them. Not sure if I've ever seen them before
