Old 05-27-2009, 01:57 PM   #1
drunkbus
New Member
drunkbus's Avatar
Memorial Weekend Project Pics.
Finally got around to doing something with my Blazer.
drunkbus is offline   Reply With Quote
Old 05-27-2009, 01:58 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Memorial Weekend Project Pics.
Great progress - what's the plan?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-27-2009, 02:00 PM   #3
drunkbus
New Member
drunkbus's Avatar
Here's a little teaser. TO BE CONTINUED....... Check out the brand new engine hoist with load leveler I got off craigslist for $100, it hadn't even been put together yet.
Old 06-01-2009, 01:15 PM   #4
drunkbus
New Member
drunkbus's Avatar
Here's a few more pics for everyone. Spent this weekend replacing the body mounts and installing a new steering gear from Red-Head. After pressure washing the engine bay and the 1/2" of grease off of the old steering gear it started leaking fluid like crazy. Also picked up the transmission from the shop, had it rebuilt with a shift kit and heavy duty torque converter and had the transfer case resealed with new gaskets and seals. The motor is a 383 stroker with World S/R heads, Crower Baja Beast cam, Weiand intake, Holley Street Avenger 670 cfm carb, and MSD E-Curve distributor. Should be a little better than the 155 horsepower 350 that was in it.
Old 06-01-2009, 02:07 PM   #5
lks dcvn
lks dcvn's Avatar
should be a lot better than the old motor
lks dcvn is offline   Reply With Quote
Old 06-01-2009, 03:32 PM   #6
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Very nice!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-01-2009, 05:23 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Very nice!!!!!!!!!!
Old 06-01-2009, 06:44 PM   #8
dirty trucker
dirty trucker's Avatar
I like your Mickey Thompson valve covers!! How big of a stall did your go with??
dirty trucker is offline   Reply With Quote
Old 06-02-2009, 01:27 PM   #9
drunkbus
New Member
drunkbus's Avatar
It's a heavy duty torque converter with the stock stall speed. The operating range for this cam is 1200-3800 RPM, it should have a lot of low end torque.
Old 06-04-2009, 10:50 AM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sweet get her together..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-04-2009, 01:42 PM   #11
drunkbus
New Member
drunkbus's Avatar
Took the day off work yesterday and got the hard part done after a lot of cussing and yelling. It was one of those days where nothing went smoothly and wrestling with the transmission and transfer case alone is not a fun thing to do, but it's all in place and bolted up. Now if the @%^& powder coater would get my brackets and pulleys done, which he said would be done 2 days ago, I should be able to be driving it again by the weekend.
I know I could have spent some time cleaning up and painting some things under the hood, but I will eventually be replacing both inner fenders and tearing everything back apart to paint the Blazer. So for now it will be left alone and I will be driving it for the summer.
Old 06-04-2009, 08:48 PM   #12
BLUE THUNDER
BLUE THUNDER's Avatar
Nice work dude. I know what you're going through. I hope to have mine running soon too. Can't wait to see more pics. Later dude, Mario
BLUE THUNDER is offline   Reply With Quote
Old 06-08-2009, 03:54 PM   #13
drunkbus
New Member
drunkbus's Avatar
It's Alive. Got it fired up late Sunday afternoon. Haven't had a chance to drive it yet, still have to put the exhaust back on, drivelines in, and button up a few little things but at least I know it is going to run and it sounds great. Barely touched the key and it fired right off.
Old 06-08-2009, 03:58 PM   #14
drunkbus
New Member
drunkbus's Avatar
Before and After
