05-27-2009, 05:28 PM | #1 |
Saving 1 truck at a time!
Longhorn Leaf Springs
PO had 2 of the 8 leafs pulled from each side of the truck when it was new due to an overly stiff ride. I am trying to replace them so I can haul a camper. I looked in the '68 GM Chassis Manual and could not find a C20 configuration, other than the coil set-up. I am now comparing my '68 to my '72 Longhorn which has only 7 springs per side but has the double stack with one spring on top, a spacer and some upper, frame mounted, spring stops. This is confusing. Anyone got a clue?
#1 - original springs removed from '68 #2 - '68 springs in truck #3 - '72 springs #4 - '72 springs
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 05-27-2009 at 05:33 PM. |
05-27-2009, 05:51 PM | #2 |
Re: Longhorn Leaf Springs
I have the same stack as on your '68 (no 2nd pack). I have had over 3000 lbs in the bed and was at about 60% capacity. Are you sure you need more? Also, not to be nosey, but it looks like you need tires and new exhaust more than you need springs...
05-27-2009, 05:54 PM | #3 |
its all about the +6 inches
the 72 has overloads, G80 if memory serves.
My one ton longhorn has the same set up. |
05-27-2009, 07:10 PM | #4 | |
LHM...Thanks...I will just assemble the extras into the pack and call it good!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 05-27-2009 at 07:13 PM. |
05-27-2009, 07:50 PM | #5 |
My 2x4 70 GMC Longhorn had 2 1/2" wide 52" eye-to-eye leafs. Those are the same as a 4x4 up to '91 except the 56" springs on Suburbans and some others. My other leaf spring 2x4 trucks (also both 70 GMC leaf spring trucks) had 2 1/4" wide springs.
