Old 05-27-2009, 06:27 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Need Source for u-Bolts for 2" Lowering Blocks
I have a pair of 2" Alum. Blocks i bought off another member w/out the u-bolts, I want to use them on my Stepper due to Rake it has with the 3/5 Drop. Anyone know a Source for just the -bolts?
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 05-27-2009, 06:33 PM   #2
caja_larga
Re: Need Source for u-Bolts for 2" Lowering Blocks
pepboys had some when I was there the other day check woth them. Also a spring shop can make them for you.
caja_larga is offline   Reply With Quote
Old 05-27-2009, 07:09 PM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
Rick,
if you can't find the size you want over the counter, your best bet for custom bent u-bolts is a big rig repair shop. probably several up in Fort Wayne. I've had several sets made at this type of business on the cheap!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-27-2009, 08:32 PM   #4
Skirkpat
Skirkpat's Avatar
We have a spring shop here that can bend them up custom, If you pay shipping I will pick them up and ship them if you can't find them local. I think they were about 7.00 a piece last time I had a set bent?
Skirkpat is offline   Reply With Quote
Old 05-27-2009, 08:38 PM   #5
cdowns
cdowns's Avatar
almost any autoparts store can get them if you have the measurements also spring shops
Old 05-27-2009, 08:40 PM   #6
Skirkpat
Skirkpat's Avatar
http://www.generalspringkc.com/index.php
This is not the place , but same deal?
Old 05-27-2009, 08:51 PM   #7
toomanytoyz
Luv the Crewcabs
Thanks for all the Input, I was able to find a Set Local that was the Right Lenght but not the Right Size diameter wise. Was afraid that to much slop would cause a problem with rear Axle.
I will have to dbl check, But i Think what i need is like 5/8 Diameter & What i bought was 9/16? The truck is at my Buddies Shop & I will check the u-bolts i Bought Tomorrow for diameter.........
I do Remember the length i bought was 12".........
Skirkpat, I Really Appreciate the Offer & Will Keep in Touch .
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 05-27-2009, 10:36 PM   #8
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Rick - let me know if you want some picked up & shipped - I just had a pair bent for my son's S10 ($27.00 for all 4)
Came with HD nuts and washers
I am going back on Thursday or Friday to pick up another set for another project
I will need Diameter, over all length & width or span
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 06-01-2009, 09:11 PM   #9
toomanytoyz
Luv the Crewcabs
Have you made your Return Trip Yet? If Not, I Need 2 of them .....
3/4 Diam x12 long with a span of 3 & 1/2.........
Just let me know........
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 06-01-2009, 09:35 PM   #10
1968SWBBigBlock
Active Member
PM sent
1968 SWB
Old 06-05-2009, 11:18 AM   #11
toomanytoyz
Luv the Crewcabs
Ubolts came yesterday, Thanks a Bunch for Doing this for Me, Rep Points your Way...........
Money order went out Today........
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 06-05-2009, 01:07 PM   #12
big_al_71
big_al_71's Avatar
Please post picts of your truck once you install them, to see how much of a difference it makes...
thanks
Al
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-16-2009, 08:10 PM   #13
toomanytoyz
Luv the Crewcabs
thanks
Al
Here is a before & After Pic , Quite Pleased with the Stance since adding the Blocks........
Many Thanks go out to Bill for going out of his way to get the Bolts for me.....
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 06-16-2009, 10:09 PM   #14
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
much better, thats on my things to do list...cheap and levels it out
John
1999 Toyota Tacoma 4x4
Old 06-17-2009, 08:15 AM   #15
big_al_71
big_al_71's Avatar
thanks for posting the picts!!!!!
definetly much better....
Old 06-17-2009, 09:02 AM   #16
my67chevytruck
Under Construction
my67chevytruck's Avatar
Rick, truck is looking good....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-17-2009, 09:15 AM   #17
Skirkpat
Skirkpat's Avatar
Scwing...Looking alot better, Red shorty's just look good.
Old 06-17-2009, 11:26 AM   #18
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Rick,
quick question from a rookie....how/ where do you install the blocks??....also, is there anything special that needs to be done to relocate the shocks or panhard bar??
Thanks.....by the way did those bumper brackets work out for you??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-17-2009, 01:58 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
The truck looks great Rick!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-17-2009, 07:48 PM   #20
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Originally Posted by gcburdic View Post
Hey Rick,
I did an FAQ article on lowering blocks with lots of good pictures. Check in the FAQ section.
Old 06-17-2009, 07:48 PM   #21
toomanytoyz
Luv the Crewcabs
Hey Rick,
The blocks just fit b-tween axle & Trailing arm, I allready had the shock relocation kit & Super panhard bar installed for my 5" Drop springs..........
The Brkts are waiting for powdercoat & will then install bumper, Thanks Again for the Great Buy on the Brkts.......
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 06-17-2009, 10:12 PM   #22
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks Tx FF....you are always a very helpful member!!!!+1
Rick
Cool Rick...thanks for this info...I'll go check that FAQ thread out....
Glad those brackets worked out....Looking forward to seeing this rollin'!!!!+1
Geoff with a G
Old 07-25-2010, 12:05 PM   #23
Cruisin' Oklahoma
Cruisin' Oklahoma's Avatar
Hey toomanytoyz,
just wondering if you could give me a measurement after you installed the lowering blocks from the ground to the fender well on the front and back? thx.
jeremy
69' Stepside, 350SB/TH350, Holley 600 4 Barrel, Headers, Edelbrock Intake, Valve Covers, and Breather, 275/60 R15's, Disc Brake conversion.
"For we know that God works all things for the good of those that love Him, to those that are called according to His purpose." --Romans 8:28
Cruisin' Oklahoma is offline   Reply With Quote
Old 07-25-2010, 12:15 PM   #24
BIG ORANGE
BIG ORANGE's Avatar
Hey looks good, great stance! I like it when member's help member's, isnt that what is all about?!?!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-23-2010, 10:34 PM   #25
bamabronc
Originally Posted by Cruisin' Oklahoma View Post
Hey toomanytoyz,
jeremy
I am interested in this measurement too
bamabronc is offline   Reply With Quote
