Old 05-28-2009, 02:52 PM   #1
nicolas72gmc
nicolas72gmc's Avatar
Coolant Capacity
Does anyone know off-hand what the approximate coolant capacity is on our trucks. I can't find it in my service manual anywhere. BTW, stock radiator, 1/2 ton, uhhh what else...... Thanks in advance.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 05-28-2009, 03:31 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Coolant Capacity
I think my 4 core takes 2.5 gallons if remeber right I just had the rad done??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-28-2009, 03:37 PM   #3
El Jay
Gone to greener pastures
It varies depending upon engine & application.
Anywhere from about 12 1/4 qts for a 250 c.i., I-6; to nearly 20 1/2 qts. for a 400 c.i. with a HD cooling system
What I do with an empty cooling system is dump in 1 gal. of antifreeze followed by 1 gal. of distilled water. Then I use the empty antifreeze jug to mix a 50:50% ratio of antifreeze to water to top things off.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-28-2009, 09:42 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ Yup. I seem to recall my 350 has about 4 gallon capacity -- I have always used 2 gallons of Prestone followed by enough water to fill the system, then I add 50/50 mix as required to the overflow jug.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
