05-28-2009, 04:04 PM | #1 |
Rear Brake 5 x 4 3/4 ?
Would like to change to 5 x4 3/4 on the rear.Already have the axles.Has anybody done a swap like this.I saw a post where somebody made a bracket so you could use a impala rear disc brake.Anybody bought it and tried the set up.
05-28-2009, 04:51 PM | #2 |
Resistance is Futile
Re: Rear Brake 5 x 4 3/4 ?
Mid 90's Impalas are 5x5 bolt pattern. FYI.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-28-2009, 06:26 PM | #3 |
Search for the rear disc brake brackets here . . ....
http://67-72chevytrucks.com/vboard/s...d.php?t=340444
