Old 05-28-2009, 04:15 PM   #1
wahlie
what's the best place to get a front disc conversion from?
Ok, I've decided to move forward with the front disc conversion on my 67 c10 1/2 ton. I've done some homework and have found a few places online. Prices range from 500-1300.00 I'm thinking that i'll do the entire front suspension while i'm in there as well. Does anyone have any place that they would recommend for a front disc conversion? I know that ECE has them but they are a bit pricey..
thanks,
Chris
wahlie is offline   Reply With Quote
Old 05-28-2009, 04:37 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: what's the best place to get a front disc conversion from?
depends if your truck is complete with the motor still installed etc. alot of people install 71 -72 complete front crossmembers and rear ends, and you could even use 73-87 chevy truck front, and rear (need to modify spring perches for coil rearend.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-28-2009, 05:02 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
the big question is how much do you want to spend, and do you want new parts, or do you want to hit the boneyard/auto recycler?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-28-2009, 05:10 PM   #4
wahlie
I'M thinking that I will probably go new... I'm going to be replacing the entire front suspension with all new components so might as well go all the way. I don't want to break the bank though. I've seen some kits for 1200 or 1400..
thanks,
Chris
Old 05-28-2009, 05:11 PM   #5
wahlie
I also meant to say that I'd ideally like the booster on here as well... I know that they have 11" ones for the 67.
Old 05-28-2009, 05:21 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I actually enjoy the challenge of doing things the hard way, so I use a late model donor and rebuild that from local parts store sources.
On my current truck, I got a 100 dollar late model front end off of Craigslist and added new ball joints, bushings, tie rod ends, calipers, pads, etc from the local parts store and Summit.
It was more work, but the final product is much nicer than a kit and the savings are significant.
Old 05-28-2009, 05:27 PM   #7
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
I'm personally looking at the ones from CPP, they now have spindles that don't mess with the spacing of the wheel in relation to the inner fender, which is great. I like that their kits come quite complete and they can sell new ball joints, arms, or whatever else you might need.
Beatcoaster is offline   Reply With Quote
Old 05-28-2009, 07:21 PM   #8
bigguy69
dazed and confused
bigguy69's Avatar
i just installed one of those kits on a 70 chevy truck. the only problem i had was with the calipers they sent me. they leaked around the banjo bolt. iwas having problems with there customer service and ended up buying autozone calipers. I also ended up putting spacers on the front because the front wheels scrubbed. the kit itself was a good kit. as soon as iget the camera working i will post some pics.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 05-28-2009, 07:33 PM   #9
67slammer
67slammer's Avatar
i used the cpp kit on my 67 with no problems, i bought the 4 wheel disc brake kit for $1200.00 well worth the money. good luck with your conversion. mike
67slammer is offline   Reply With Quote
