Old 05-28-2009, 09:39 PM   #1
Leon E Morris
Question need help with disc brake conversion
i have a 1967 1/2 ton c10 pickup and want to put 5lug disc brakes off a 1971 1/2 ton c10 on mine my question is it a simple swap or do i need to change ball joints , tie rod ends ect. for a 1971 truck all help would be greatly appreciated thanks leon
Leon E Morris is offline   Reply With Quote
Old 05-28-2009, 10:03 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: need help with disc brake conversion
You will have to change the ball joints too. Swap the entire steering linkage from spindle to spindle too. It's a real fast swap that way.
If you don't want to spring the coin for the new 71 spec ball joints, just swap the entire 71 control arms onto your truck. That way you can reuse the donor ball joints.
Old 05-28-2009, 10:19 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
yeah wat he said lol
so wat ya gonna do
John
1999 Toyota Tacoma 4x4
Old 06-02-2009, 07:06 PM   #4
Leon E Morris
thanks tx are the pitman arm and idler arms the same
