Old 05-28-2009, 10:24 PM   #1
1987_3/4ton_chevy
Cowboy Up
Rear "cross member"
I am wondering what is the Techanical name for the rear Cross member is called. Its right before the rear axle and goes from one side of the chassis to the other.
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 05-28-2009, 11:22 PM   #2
ripdog28
ripdog28's Avatar
Re: Rear "cross member"
You mean the one with the driveshaft hoop or the one just behind the axle? I dont know what the technical name is but the rear one is not needed.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 05-30-2009, 10:20 PM   #3
1987_3/4ton_chevy
Cowboy Up
Here are some photos of what i am talking about... need help!!!
Chris Cary
Old 05-30-2009, 11:19 PM   #4
ripdog28
ripdog28's Avatar
yea that is above the axle. it is the rear shock mount brace. It appears someone did some modifications. Was your truck an original leaf spring? i see your leaf spring does not align with the cross member for your shocks to line up. I do not know what happened there. IMO it is not needed and i would cut it out completely i would weld/bolt another square tube like 2inx2in somewhere to mount the shocks at the proper angle. are those 2 bolts from both sides where your shocks were mounted? you should stick with those but i would still put another cross brace in there somewhere just to stiffen the frame up.
69 c-10 BBC
Old 05-31-2009, 03:20 PM   #5
1987_3/4ton_chevy
Cowboy Up
so all i need to do is get someone to weld a piece of metal to connect both sides, am i understand this right then? Any bends or anything i need to do also with this or not?
Chris Cary
Old 06-01-2009, 09:28 AM   #6
1987_3/4ton_chevy
Cowboy Up
Chris Cary
Old 06-01-2009, 09:45 AM   #7
ripdog28
ripdog28's Avatar
a piece of 2in square tube welded there will do fine. all you want to do is stop the frame from flexing. no bends.
69 c-10 BBC
Old 06-01-2009, 10:31 AM   #8
67chevy3/4tontruck
not sure of the true name
67chevy3/4tontruck is offline   Reply With Quote
Old 06-01-2009, 10:44 AM   #9
67chevemall
67chevemall's Avatar
Your gonna need one of those
I would hit up the wreckers and get the oem one in there.
I can get Harold to get ya one if ya stuck.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-01-2009, 01:57 PM   #10
1987_3/4ton_chevy
Cowboy Up
How much would he charge or would be easier to have a welder do it
Chris Cary
