Old 05-29-2009, 12:14 AM   #1
1964C10
1964C10's Avatar
FYI - Ebrake cable boots
This post is purely informational and pertains to my 64 C10 longbed fleetside but may to others as well I imagine.
It started when I was looking at the pictures in the catalogs for new ebrake cables for my truck and none of them showed the boot where the cable comes out of the sheathing so I called classicparts.com and LMC and both assured me it came with it. As it turned out the classicparts.com did not come with anything and the LMC one came with the purplish boot in the picture, it feels like a really cheap silicon type rubber. So I went on a quest to find "the boot" I ended up at Jim Carter and they listed a boot for 36-59 cables but it looked exactly like what was on mine (the old one in the picture) so for $3.56 I ordered a pair. Well they came in today and they are exactly like what I have, same length, same opening, right down to the little tabs/bumps on the side (green arrows). On my old the little other opening broke off when I removed it from the cable (white dashed circle). The boot connects to the cable in the ridge indicated with the red arrow. Well it's kind of a wordy post but maybe it might help someone if they are looking to do a more period correct restoration.
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 05-29-2009, 07:47 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: FYI - Ebrake cable boots
Thanks for sharing...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-09-2009, 01:02 PM   #3
damnyankee36
damnyankee36's Avatar
1964C10,
Did you have any problems in sliding the boot over the swagged ends of the cable?
I finally found a couple of used boots that weren't rotted and they still split a little when I had to stretch them over the ends of the cables. I would guess with the boots being new, they would stretch a little better than old ones.
damnyankee36 is offline   Reply With Quote
Old 06-09-2009, 01:45 PM   #4
1964C10
1964C10's Avatar
I haven't put them on yet but I should be getting to that here in the next day or so. I am planning on using plenty of lube of some kind lol
1964 Fleetside LWB
1996 Camaro Z28
My build thread
