Windshield trim and rubber?
There was a thread awhile ago about the different style and years of windshield trim and I can't seem to find it. I've got a '71 with the stainless trim around the window, and I need a new gasket. I remember in the other thread something about getting either a '67-'70 or the '71-'72 year because one was easier. Anyone have any info on which one I should get? I need to call Tim Christian soon to order these and want to get the right one the first time. Thanks - Chad
Re: Windshield trim and rubber?
That stainless trim is a bear to get back into that gasket, I just went with the plain jane gasket, sometimes less is more on certain trucks, My trim is in good shape if you need a set for a 71
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() Last edited by UltraBlue71; 05-29-2009 at 09:40 AM. |
motor exploder
I had to replace my windshield that had the trim in it, ordered the trim and gasket, had it installed and it leaked from day one. ended up going with the regular gasket also... It really doesn't look much different to me, and I really enjoy my floor board not filling up with water when I was my truck...
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
You need the 71-72 rubber. The stainless trim is I believe shorter on the 71-72 and I think is easier to install. The rubber is made for the different lengths (depth) of the stainless backing(mounting). The shorter depth of the stainless might go in the longer rubber, but I am not sure if it stays in properly. If you had the two side by side you would know exactly what the difference is. There is probably a thread on here. If you buy NOS, make sure you have the correct one as there are two part numbers. If I remember, I had the stainless in the rubber before we installed the windshield.
The Older Generation
I put the trim back in my '71 and I didn't find it any harder to install than the non trim ones. Whether it leaks or not I don't know, I will probably find out this weekend when I go to the 67-72chevytrucks.com Midwest Board Meet in Kirksville, Missouri.. ![]() Go to the Google search box at the top of the page and type in "windshield trim" without the quotes, click on the circle in front of "67-72chevytrucks.com" and click on the Google button. LockDoc
#6 | |
Here is a link. Not sure if this is what you were looking for. Installing Window Trim
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Thanks for the help guys. I think I found the info I needed. I'm going to have a glass company install it. They said $200 for new windshield installed if I supply the rubber. I didn't ask if the install the trim with it also. I guess I;ll find out when the time comes. I decided to paint my dash, and its turned into a full cab strip down with removing glass and all.
do you guys use a piece of rope to install your glass? a ole boy showed me that trick once works real slick!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() Last edited by UltraBlue71; 05-29-2009 at 01:57 PM. |
![]() Join Date: Jan 2008
Use sash cord and some silicone spray,a cotter pin removal tool also helps for the corners. You can pat the glass in as you pull the rope but don't hit too hard and never use a fist,only an open hand.When you put the rope in the pinchweld groove in the rubber start at the center at the bottom,wrap it around and twist it together ,that way when you start to pull,
