05-29-2009, 10:16 AM | #1 |
Loving the Jimmster
Replacing the hump!
Does anyone know if you can buy a new hump? I have a high hump and going to go with a new column, so i would like to get a new hump for the chev??
Thanks Vance |
05-29-2009, 12:48 PM | #2 |
Re: Replacing the hump!
Are you wanting to convert it from a high hump to a low hump? Or are you just wanting to replace a damaged high hump?
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
05-29-2009, 02:11 PM | #3 |
Loving the Jimmster
to replace a high hump. It kinda looks like the low humps are part of the floor?? might have to do some custom stuff to lower it??
05-29-2009, 05:44 PM | #4 |
its all about the +6 inches
they do not reproduce the high hump cover at all.
05-30-2009, 09:09 AM | #5 |
Loving the Jimmster
So correct me if i am wrong, the high hump is for a standard and can be removed. The low is for an auto and can not be removed (part of the Floor)?? If so has anyone modified a high hump to lower and give you a better look.
05-30-2009, 09:32 AM | #6 |
Just like to part out trucks!!
Vance, what some guys do is take a section from a low hump cab and weld it in to get the low hump. Yes high hump is bolted in and can be removed, low humps were made from factory in one floor section
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
05-30-2009, 01:07 PM | #7 |
So you have a 4 speed floor shift, and you want to go to a auto trans/ or a column shift? These trucks did come with a high hump and an automatic( granted they were BB ). So why don't you go to the parts board and buy a high hump without the hole for a shift/4x4. Either that or just weld up the hole in your hump. It would be alot easier than trying to turn you truck into a low hump cab.
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-30-2009, 01:54 PM | #8 |
Trucks N Tranzams
Undamaged High humps can be pricey. They were definitley less common.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
05-31-2009, 01:48 AM | #9 |
I didn't get one with my truck so I made one
05-31-2009, 02:47 AM | #10 |
You know they have two trucks at Gem Co auto wrecking right here in town They might have what you need both those truck are just about rust free. I'm going there on monday for some other stuff if you would like me to check for you I can let me know
71 GMC 1 ton dually tow truck "Cooters tow truck from the Dukes of Hazzard" 1988 chevy 1 ton 4x4 Chevy step van "dont know what to do with it yet LOL" 1940 chrysler 1949 dodge panel rat rod 1989 jeep cherokee "With a 8 inch lift and a ton of other stuff and two parts jeeps" Then the wifes van LOL |
05-31-2009, 02:51 AM | #11 |
Also I have seen guys take a bolt in hump and set it over a non bolt in hump then cut it out and just make it bolt in with the right cuts and holes drilled. I think there was a write up on it posted not long ago
05-31-2009, 09:34 AM | #12 |
find a truck with abetter hump in it
