05-29-2009, 04:30 PM | #1 |
It followed me home?
Noisy ac compressor at idle
So I just changed the siezed up ac compressor in my work truck, charged it with 3 cans of freon and it gets cold and works like it should. The one problem I am having is at idle it makes a grinding noise? Did I put too much freon in maybe? the compressor has oil? any suggestions?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
05-30-2009, 10:25 PM | #2 |
BAD BOW-Silverado XST
Re: Noisy ac compressor at idle
Is the compressor rebuilt or new? I had one that sound like that at idle. It worked for a long time before it blew up.
05-31-2009, 12:57 PM | #3 |
Robert Olson Transport
is it the clutch ( only happens when ac is on) or the bearing (all the time) if its the bearing that compressor is on it s way south too
06-01-2009, 11:44 AM | #4 |
On a budget like Fred Sanford
Mine does the same thing if the idle rpm drops below 650, growls real bad. Anything above that and it doesn't growl. No idea what is making the noise......It's a reman compressor and blows cold/works fine otherwise.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
