Old 05-30-2009, 04:27 PM   #1
babbyblue66
HELP electric problem
I have a 66 chevy stepside now what happened is my head lights will only work on high bean the low beam setting just turns off the lights but when the high beams are on it seams to draw off the battery more then the alt can handle and slowly kills the battery before some one asks the battery has checked out and the alt as well could the hole problem be the dimmer switch?
Ive tryed everthing i can think of now its time pick you brains so i can fix this
babbyblue66 is offline   Reply With Quote
Old 05-30-2009, 06:12 PM   #2
the lights
the lights's Avatar
Re: HELP electric problem
before replacing the dimmer can you bypass it and see if the low beams work?
the lights is offline   Reply With Quote
Old 05-30-2009, 06:26 PM   #3
babbyblue66
i didnt think of that but would the dimmer draw power and cause the battery to die
Old 05-30-2009, 07:22 PM   #4
slepysal
slepysal's Avatar
search for relays , or check the faq for head light relays.
check the plug conection at the fire wall , check your grounds, and your head light switch, make sure all are clean
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 06-03-2009, 07:50 PM   #5
chris91
My 66 does not have relays. I had the same problem check connectors and bulbs. remove the connector from the dimmer switch and do the jumper.
chris91 is offline   Reply With Quote
Old 06-03-2009, 10:49 PM   #6
slepysal
slepysal's Avatar
none had them oe , add some you will be pleased brighter lights less draw on your battery
Old 06-04-2009, 01:16 PM   #7
babbyblue66
hey thanks a lot you guys i had some bad conections and the dimmer was al messed up so i jumped it and cleaned out all the conections and now my heads lights are brighter then ever but i dont know if i fixed the draw problem yet i just put a full charge and im waiting to see what happens
