Old 05-30-2009, 10:19 PM   #1
mrmojo32
mrmojo32's Avatar
1985 GMC Jimmy gear ratio?
Does anyone know what rear axle gear ratios were offered in 1985 GMC Jimmy K5 - 12 bolt?
I have tried to do some looking on the old brochure sites but the fine print is too fine to read.
Thanks in advance.
1972 LWB
1969 4x4 Suburban
1989 4x4 Jimmy
mrmojo32 is offline   Reply With Quote
Old 05-31-2009, 09:08 AM   #2
b454rat
Re: 1985 GMC Jimmy gear ratio?
Not that it matters, but will be 10 bolts front and rear. And gears could be anything from 2.73s up to 4.10s. Check in the glove box for the RPO codes, or could be under the hood on the inner fender. Starts with a "G".
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 05-31-2009, 09:00 PM   #3
mrmojo32
mrmojo32's Avatar
Well I thought 10 bolt too but the guy who has the truck says that the rear is 12 bolt.
1972 LWB
1969 4x4 Suburban
1989 4x4 Jimmy
Old 05-31-2009, 09:17 PM   #4
silvereagle07
silvereagle07's Avatar
Take the covers off of the diffs and count the number of teeth on the ring gear and divide it by the teeth on the pinion.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 05-31-2009, 10:03 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
My truck has a 12 bolt rear end and it is an 84 Sierra classic. The gearing could be 3.08, 3.42, 3.73, or 4.10. In those days you could STILL order what you wanted in a truck.
piecesparts is offline   Reply With Quote
Old 05-31-2009, 10:35 PM   #6
mrmojo32
mrmojo32's Avatar
Right on about counting teeth or sometimes there is a number stamped on the ring gear that you can devide to get the ratio. I was asking because I do not have the Jimmy in my possession. I am going to pick up the front and rear axles tomorrow without know what ratio they are. I am just hoping that they are not 3.08.
1972 LWB
1969 4x4 Suburban
1989 4x4 Jimmy
