Old 05-30-2009, 10:34 PM   #1
jdfrmnt
HELP tell me about timing
i failed the smog check i have my timing set at 2 btd and my carb screrws out 3.5 would setting my timing at 10btd help any info would help o ya smog is due today my bad
jdfrmnt is offline   Reply With Quote
Old 05-31-2009, 12:46 AM   #2
Pont406
Re: HELP tell me about timing
What did you fail on?
Pont406 is offline   Reply With Quote
Old 05-31-2009, 06:41 AM   #3
jim zag
ENGINE BUILDER
jim zag's Avatar
What kind pf carb? Most carbs use a starting point of 1.5 turns out. I would use 8 degrees BTDC as a starting point for base timing.
JIM ZAG
jim zag is offline   Reply With Quote
Old 05-31-2009, 07:07 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
very good question. give us the results so we can tell you what to do. we also need to know your setup ie; carb, cam, heads etc.
68C15 is offline   Reply With Quote
Old 05-31-2009, 10:46 AM   #5
capev86
i think it is supposed to be more like 8 degrees before top dead center. i set the 307 in my 72 burb to that and it runs awesome. i also converted to electronic ignition with a petronix ignitor kit from lmc and a new cap (better unit with brass studs) and rotor from napa. also have a set of cheap wires and ac delco plugs to go in next and hope that will iron out the last bit of bucking (already much smoother than it was). i'm thinking the 37 year old wires are past their peak and the plugs probably haven't been changed either owing to the fact that the original owners didn't drive it regularly...73,000 original miles!!!
capev86 is offline   Reply With Quote
