05-31-2009, 02:40 PM | #1 |
np 205 vs np 208
ok i have a th400 with a np 208 behind it will i get lower gearing if i switch to a np 205 or is it just a stronger t case? does any one know the gearing fro a 208 and a 205?
05-31-2009, 03:52 PM | #2 |
profeshinaly unimployed
Re: np 205 vs np 208
im purity shure the 208 has the lower gears
"having mud flaps is like asking for a smaller trophy" |
05-31-2009, 09:59 PM | #3 |
IIRC the 208 has a 2.72-1 low side and the 205 has a 1.96-1 low side
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
05-31-2009, 10:10 PM | #4 |
so the 205 would be alot better for truc pulls then if it has a lower 4 low.
06-01-2009, 07:13 AM | #5 | |
Higher number = Lower gear ratio
Tim |
06-01-2009, 11:46 AM | #6 |
But the 205 is a much stronger case though
06-01-2009, 12:18 PM | #7 |
the 205 is a stronger case.....but i love my 208 and it hasn't broke on me yet
06-01-2009, 12:54 PM | #8 |
the only problem i am having with the 208 is it doe not want to stay in 4 low i have it adjusted as far as it will go and it seems like i have to hold in in low when i pull. is there something i can do with it? can i thred the rod more to have the shifter pull it more into 4 low? thanks for all the info.
