Old 05-31-2009, 03:44 PM   #1
Pont406
summit radiator
Before I was running a 4 row radiator. Nothing was wrong with it and I had it boil out. Around town it was running at 175-180. On the freeway it was running hot 210-220. 4 row radiaotor just wasn't getting enough air through it at high speed.
I installed a summit universal 2 row radiator and aux trans cooler rated at 17000 GVW. With no other changes now it runs at 165 and 175 on the freeway. Fans only come on when idling for 15 min or more and temperature comes right down to 160. So far I am happy with it.
Pont406 is offline   Reply With Quote
Old 05-31-2009, 03:50 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: summit radiator
Do you know what brand of 4 row radiator you had?
A lot of people recommend them to keep the engine running cooler, but as you mentioned, there's also air movement restriction to consider.
I wonder if it's true of all 4 core or just certain brands? Maybe someone else can post their experience since I had been thinking of getting one.
68gmsee is offline   Reply With Quote
Old 05-31-2009, 03:55 PM   #3
Pont406
Re: summit radiator
It was a harrison(sp?) 4 row radiator out of a 70 firebird. A little bigger compare to a stock 4 row. My car and truck both had the same problem with running hot on the freeway with 4 row.
Old 05-31-2009, 04:11 PM   #4
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: summit radiator
That aluminum radiator is far more efficient. I have aluminum radiators in everything I own with similar results.
I ran a Desert cooler 4 row copper radiator in my Trans Am for a while and it struggled to keep the temp down with my A/C on. I bought a BeCool 2row aluminum radiator for it and it dropped the temp about 15 degrees from 220 in the same conditions.
The key is airflow
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-31-2009, 10:15 PM   #5
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: summit radiator
How did that summit universal 2 row radiator Fit What size motor do you have? Did you have to modify anything to make it fit did you come across any problems installing it, Whats the Summit Part #? That summit radiator Looks good I have been thinking of buying one myself and those summit brand universal 2 row radiators have a good price...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 06-01-2009, 05:47 AM   #6
jim zag
ENGINE BUILDER
jim zag's Avatar
Re: summit radiator
Aluminum radiators do a GREAT JOB!!!!
JIM ZAG
jim zag is offline   Reply With Quote
