Grandpa in the rustmobile...
how to remove steering wheel?
okay, got the cap off, the the horn button thing, then the 3/4 nut, and pulling like crazy and nothing, wats next lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
![]() Join Date: Sep 2007
Re: how to remove steering wheel?
you have to get a steering wheel puller. you can usually borrow them from autozone, or o reilys,checkers. be sure and put a mark on the wheel and the hub so you can re-align the wheel properly
1967custom |
lol its already not aligned properly...
is there anyway i can pull it without the steeriing wheel puller? thanks!
#4 | |
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 05-31-2009 at 05:23 PM. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Maybe if there's room behind the wheel to swing a bfh
![]() I bought a wheel puller many years ago -- cheap, and a great investment. It just works so well for the purpose. ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-31-2009 at 05:25 PM. |
ima try a gear puller brb i'll letcha know how it goes lol
didnt work ou tlol
with the shaft nut loose even with the ends of the threads but not off you scrunch up in the seat put pressure on the back of the steering wheel with your knees then with a hammer yougive the nut a good solid whack //it's usually good enough to break the wheel ffree of the shaft taper// have done this hundreds of times and havent damaged a thing
o well too late its all back together now lol
will a 72 steering wheel fit a 68 ima try to fix the cracks that're in mine lol
#10 | |
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() |
its all about the +6 inches
a $15 cheapie puller is a good investment. It can be used here and there, and doesn't take much room at all when not being used.
Ive done the pull methos, I've done the hammer method, and in all reality, it just isn't worth it. |
