Low & Slow
I am needing a vacum diagram for a four barrel quadrajet with electric choke. I'm also having trouble with the choke staying on at all times so the back two barrels aren't even opening. Anything will be a big help thanks
Hey Hotrod, what part of Moore do you live in? We used to live on NE 15th until 2 months before the big 'nado came to town!
There isnt really alot to the vacuum on these trucks, someone correct me if im wrong: Brake booster Vacuum advance Canister purge/Vent PCV Where is the power coming from for your choke? Make sure its a constant 12v with key on. If power is always there, you could have a bad choke coil or its just adjusted way to tight. |
Low & Slow
I live off of southeast 12th street. My choke is powered off the stator. I unhooked the choke and put a load on the motor and the secondaries still won't open. I'm trying to get this all sorted out before i start putting together my new motor. The reason i was needing a diagram or is that I have a bunch of open vacum ports. Sorry if i'm not giving you anything to work with....
I have another question also. What did q-jet model #17057204 come off of originally? |
