need some help
i want to take out my 250 out of my 66 c10 and put in a 350, what will i need to do to make this happen, ie, do i need a new bell housing? clutch? what do i do for mounting the engine and what headers will fit?
#2 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: need some help
As for the parts you are looking for, take a look in the classifieds here on the board and also check out the board vendors that sell those type of parts. Sometimes new parts are the best way to go.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by redneckgirl; 06-01-2009 at 07:16 AM. Reason: removing part of quote |
Re: need some help
thank you, im going for loud and looks, dont want to do performance, thats what i have my 72 nova for, i was also wondering, are the pedals adjustable, theyre uncomfortably close to the seat, theres a lever under the dash connected to the pedals, and also what are the usual MPG for the 250 with 4 on the floor
#4 | |
60-66 Nut
Re: need some help
That would be your e-brake lever. Do you have the seat all the way back? sometimes the seat adjusting mechanism is broken or jammed. There's really no easy way to move the pedals. Sorry don't have a clue on the mpg for a 250.
Re: need some help
yes the seat is back,are the pedals in normal location, you have to mve your leg back and lift it about 6 inches, this is for the clutch and brake pedals, and thank you for the help
Re: need some help
can anyone tell me the mpg with a 250 and 4 on the floor
60-66 Nut
Re: need some help
Yes you do have to lift your foot a bit to get to the pedals. This is likely to be a little more noticeable if you are tall and/or have long legs. Driving these trucks isn't like driving a car.
Re: need some help
ya, i had a 64 and the pedals werent this bad tho, so idk
60-66 Nut
Re: need some help
You might check and see if the rubber bumoers for the pedals are there. If they're gone the pedals will sit higher from the floor.
Re: need some help
its not so much the height i care about, its how close they are to the seat, only about 7 inches
60-66 Nut
Re: need some help
If your pedals are only 7 inches from the seat, there is something seriously wrong there. Is the seat original? Are you positive it is all the way back against the rear of the cab?
Some pics might be the best way to figure this out. Take a pic of where the pedals are under the steering column, a pic of the seat, and a pic standing on the ground looking in the drivers side of the cab.
Re: need some help
alright, ill get them asap
