Old 05-31-2009, 11:07 PM   #1
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
I need your guys' support please.
Most of you have seen the pink (I still don't know the factory name for the color) '63 GMC I drive. Recently it has been declining in the running department. It all started when the Air Zenith compressor took a dump. Then the Viair took a dump. After that the electrical to the compressor caught the truck on fire three times in one week. Then the motor developed an intermittent miss under load and then started missing more frequently. Last week it dropped a cylinder, caught fire pretty bad (fourth one!) and now it hits on all eight but loses cylinders at idle. It runs so rough that it won't idle period. The mill has less than 20,000 miles on it too! Some buddies had to wrestle the gas can away from me this weekend as I was going to simply torch the thing up and watch it burn. That would be a shame though as this truck doesn't even have 47,000 miles on it. Wanna help lift my spirits here?
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 05-31-2009, 11:11 PM   #2
**grumpy**
**grumpy**'s Avatar
Re: I need your guys' support please.
Haha. Dont know where to start...
Just walk away. It will be easier once you've taken a step back.
That helped huh??
Road Hounds
**grumpy** is offline   Reply With Quote
Old 05-31-2009, 11:13 PM   #3
Imperial Kustom
100% gearhead
It's my daily driver though.
Imperial Kustom LLC
Meridian Idaho.
Old 05-31-2009, 11:16 PM   #4
joe231
joe231's Avatar
I feel your pain and frustration....but it will get better....How is that for some motivational speaking?
stare into my avatar and the world will be right again..........
CHEVY ONLY
Old 05-31-2009, 11:24 PM   #5
bubba327
HOW long until spring??
bubba327's Avatar
If you have fires it sounds like electrical issues. Maybe old or undersized gauge wiring to compressor or other added loads? Does the battery stay charged? Is the alternator large enough? Check fusing. Fuses properly sized should open the fault before a fire occurs. Low voltage or alternator problems could cause weak spark at idle. Like Grumpy said --step back and think first --Sleep on it
It will be simple once you find the problem -- good luck
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 05-31-2009, 11:25 PM   #6
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Since you can't step away from it cuz it's your daily driver, go buy another truck and choose the lesser of the 2 evils to be the daily driver. Then fix the one you don't drive. just my .02
Alan's Classic is offline   Reply With Quote
Old 05-31-2009, 11:27 PM   #7
bubba327
bubba327's Avatar
How is the vacuum? any melted/ leaking hoses?
Old 06-01-2009, 07:30 AM   #8
jason65
Registerd User
jason65's Avatar
What motor is it? When sparkplugs get fuel soaked they will act like what you are saying. How did #4 catch fire? You talkin about plug wire? Need more info. Is it running ritch? Old distributer? Fuel in motor oil?
jason65 is offline   Reply With Quote
Old 06-01-2009, 08:22 AM   #9
jbgroby
jbgroby's Avatar
I wish I could say something enlighting like the other guys, but they have covered the bases already.
However, maybe it's so low to the ground that the earths magnetic force is affecting the coil emmisions and the comm's systems is overloaded?
jbgroby is offline   Reply With Quote
Old 06-01-2009, 08:32 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I know the feeling... I thought I smoked the cam in my 65, I was trying to figure out where and how to get another motor or chang the cam....
then a friend listened to it and mentioned that it was just a broken spring on the fuel pump
you can just air up your bags to ride hieght and leave them can't you?
the sbc might be smoked.. but luckily they are one of the cheapest of any engine choice you could have.
might be easy enough to put a cheap runner in it if you can source one.
***you have probably thought of this.. but carry a fire extinguisher!***
Last edited by jonzcustomshop; 06-01-2009 at 08:33 AM. Reason: missing a lower case "t"
Old 06-01-2009, 10:53 AM   #11
protrash64
Resistance is Futile
protrash64's Avatar
I think its time for a wiring harness upgrade. You oughta be able to thrash it in there in about 2 hours judging by how fast you got the truck done. Sounds like you have something drawing alot of juice and damaged wiring. Are your compressors running off a relay? What alternator are you running? I'd also check the starter circuit out; I had a complete meltdown destroy my starter and battery one time.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-01-2009, 06:29 PM   #12
Imperial Kustom
100% gearhead
I got off work a little early today, went to the DMV, and registered my '97 Sonoma. Daily driver problem solved. I also pulled a new ignition module out of my stash-o-parts, so we'll see what happens. As for the first three fires, all were caused by a faulty switch to the compressor, which has an inline 40 amp fuse and a relay. The fourth was because the starter is taking a dump. I went to crank the truck over and the starter drew WAY too much on the system and smoked all the underhood wiring. New starter will be here tonight. I put a new harness in and yes, it did take about two hours! The miss has me boggled. At first it was only under load in third and fourth. Had me thinkin the advance mechanism in the distributor might be toast. IT WAS SCREWED!!!! Rebuilding did not help though. Now the miss likes to swap cylinders. Number one and six. Telltale signs of a vacuum leak, so I will test for that too. If none of this works, I will also check the valve action. I already had to replace one set of heads and pushrods in this motor due to bad gas varnishing and sticking the valves. I am the guy who never gives up. I will conquer this B!*ch!!!
Imperial Kustom LLC
Meridian Idaho.
Old 06-01-2009, 06:30 PM   #13
Imperial Kustom
100% gearhead
oh. The alternator is 65 amp.
Imperial Kustom LLC
Meridian Idaho.
Old 06-01-2009, 06:55 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Originally Posted by Imperial Kustom View Post
......As for the first three fires, all were caused by a faulty switch to the compressor, which has an inline 40 amp fuse and a relay. ......
If your wiring is catching fire, your fuse is mis-sized for the wire gauge. It's that simple, the fuse should be matched to the wire size. Apparently, whatever size of wire you are running is not rated to carry 40 amps. You need either a bigger wire or a smaller fuse.
Old 06-01-2009, 09:44 PM   #15
Imperial Kustom
100% gearhead
yeah. the fuse is between the compressors and the switch, Terrible place, I know. But I did figure out my miss. Apparently the power lead to the HEI wasn't carrying a full 12 volts. Rewired it and I'm good to go! Just waiting on the starter and blanket now and all systems should be go and I should be back in reliabilityville!!!! Thanks guys for all your support and input during my emo moment. That's why I love this site!
Imperial Kustom LLC
Meridian Idaho.
Old 06-01-2009, 10:29 PM   #16
Dadsredwagon
Dadsredwagon's Avatar
it may be a pain now, but i love the feeling when I drive by some one in a nice NEW ride and get the thumbs up!!! way too many good times will come for you hang in there
Dadsredwagon is offline   Reply With Quote
Old 06-01-2009, 10:50 PM   #17
protrash64
protrash64's Avatar
For 40a circuit you should use a #8g wire at least...Id bump it to #6 if you only have one compressor and a large tank.
Old 06-01-2009, 11:09 PM   #18
bubba327
bubba327's Avatar
On coil/points distributors there was a resister wire in the harness which dropped the voltage down to save the points. The starter had a set of contacts which closed and sent full voltage to the coil only while the starter is engaged. Moral of the story-If you install a HEI-- find and remove the resister wire and replace it. Glad you are progressing-- Imperial Kustom We have not met yet but I passed you the other day on Chinden. Truck looked good.It was not on fire at the time!!!
Old 06-02-2009, 02:52 PM   #19
Imperial Kustom
100% gearhead
Thanks guys! Up 'til now, this truck has been super reliable, and the '62 was as well before I pulled it off the road. The compressor cable is indeed 6 gauge wire! It's a fat mother faker!!! Hopefully the new starter with a heat blanket will solve my woes as far as that goes and I can go back to worry free cruising, which I do a LOT! This stupid thing gets better than 400 miles to a tank, so I drive the wheels off it! Thanks for the compliment Bubba! Can't wait to meet ya in person one-o-these days. And feel free to call me Cameron.
Imperial Kustom LLC
Meridian Idaho.
Old 06-02-2009, 05:30 PM   #20
naynay
just post up some pics from it's hay day and let us all stare at them
naynay is offline   Reply With Quote
Old 06-02-2009, 10:59 PM   #21
Imperial Kustom
100% gearhead
Its already in its heyday. She's back up and runnin like a champ as she always does!
Imperial Kustom LLC
Meridian Idaho.
Old 06-02-2009, 11:08 PM   #22
joe231
joe231's Avatar
where are the pics then???
CHEVY ONLY
Old 06-03-2009, 09:13 PM   #23
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Joe, askin for pix, never!
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 06-03-2009, 10:40 PM   #24
joe231
joe231's Avatar
CHEVY ONLY
Old 06-06-2009, 07:37 PM   #25
Imperial Kustom
100% gearhead
Theyve been posted on here before, but I know you guys still need your fix!! It's got a front bumper on it now too...
Imperial Kustom LLC
Meridian Idaho.
