Stock 454 exhaust system size?
I am looking for the exhaust size for the pipes that would have came on a stock 454 truck. I am assuming it was a single pipe setup rather than duals, but am unsure. I just wanted to have something for reference, and the Walker OE catalog doesnt show anything for a big block.
Re: Stock 454 exhaust system size?
On Summitracing.com, I found a direct fit cat converter that says 2.5" for 75-79 C10 with 454. So I assume that was the stock size.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 06-02-2009 at 09:46 PM. |
78 Big10 454
![]() Join Date: Jul 2008
383Ram, my 454 exhaust is 2.5 inches factory stock. 1978 C-10.
![]() Join Date: Apr 2009
my 1977 c-10 454 has factory duals w/ no cats and no "unleaded fuel only" decal on the fuel gauge. i think the factory size is 2 1/2
1981 Chevy C30 440 Holmes 42K one owner miles |
I assume all these systems are single--except for the last post? I am trying to get a feel for what the factory used as to what i want to do with my system. I know the factory tried to comprimise on power and quietness, which is what i want to also. I am just having a hard time believing that a 3" single system (which is on the truck now) will be adequate for a 454 that is going in. I may have to scrap it and start over.
#6 | |
Any idea why that might be? I recall our '75 C10 350 was a single exhaust with a cat (because - back in "the day" - we blew the cat up, scattering the pellets all over the roadway). Was your truck built in Oshawa or had some other emissions package? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-03-2009 at 11:42 AM. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If the 454 was heavy half'd the cats wouldn't be required in some states....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
78 Big10 454
From the factory, I had pipes coming off the exhaust manifolds into one Cat then branching off to two mufflers and tailpipes. I modified it by running a dedicated Cat and muffler on each side. Although technically illegal by California standards, I've never been caught at the biennial smog tests. In short, both systems were 2.5 inch.
