Fuel Lines..What are you using?
I have a Edelbrock manual fuel pump with a 5/8 threaded output and a Edelbrock 1406 with a 3/8 line inlet. Anyone run this combo? What are you using to get the fuel up there? Hose, making your own fuel line? I wouldn't mind using braided hoses but am not sure how to secure them,and am also having trouble finding 5/8 fittings for the pump..
member #16
![]() Join Date: Dec 1999
Re: Fuel Lines..What are you using?
Dont those pumps have a 3/8 NPT fittings in and out?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
sorry, yes, 3/8..that is why I had trouble finding the fittings...Still need to find a way to route the fuel up there.
That's right, it's Copper!!
Try something like this.http://store.summitracing.com/partde...5&autoview=sku
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
Aeroquip makes some good products, its not too hard to assemble lines with thier products either, I've used Aeroquip stuff on aircraft (I'm a fighter plane mech in the USAF) but never on vehicles, same concept, bet its expensive though!
http://apps.esg.aeroquip.com/product...roquipmain.asp
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() Last edited by UltraBlue71; 06-02-2009 at 12:36 AM. |
ENGINE BUILDER
I use aeroquip fittings on all the engines I build.I like to use the PUSH LOCK rubber hose because it is much easier than the braided stainless. Just buy the jaws to use in a vice and lube the fittings and hose and push together. you can not pull this stuff apart!!! It is EASY!!!!
JIM ZAG |
I used the Aeroquip Socketless AQP hose, and bought all the fittings to make everything from fuel sender to carb 6AN. I didn't have the vise tool as mentioned above, and only had problems getting one of the fittings on. I just cut it off and started that one over. Went on fine the 2nd time
![]() It's very tough stuff. |
I bought braided hose and used anm fittings...see picts of the fittings and in the second picture you can see how it is connected to the carb.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
its all about the +6 inches
rubber hose is a bad idea.
Bending steel lines is very easy, very cheap, and should last longer than the truck. |
I used Aeromotive -6 AN fittings and steel braided line. Works great.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#13 |
![]() Join Date: Jul 2007
I believe that if you check the Aeroquip online catalog they have hose that is rated for gasoline.
On the steel line, if you take the die for your double flair tool and partially do the first step <l l> it makes a nice knob to us with a rubber hose. I'm with Longhornman in that I don't like to see long runs of fuel hose on a rig where a properly bent steel hose should be. As far as braided line and AN fittings I think that is a personal thing and if you are going for that look great but otherwise it is hard to justify the expense over a good steel line. If your engine is all billet with all the tricky slicky pieces it is part of the deal but if you are running mostly chrome goodies or no goodies it may be an excess. |
#14 | ||
I never said it was.
I said; Quote:
I left my personal opinion on the braided hose out of the equation, and only stated cold hard facts. I've worked on heavy equipment and heavy duty over the road trucks my entire adult life. I could bore you with details on each material mentioned in this thread, but I'll get crapped on by all the people who want to run each one of the high dollar methods... all which are way overkill for any street driven truck. It is hard to beat steel tube, which can be bought in lengths to complete the job already flaired on each end. It's cheap, it's effective, it can be made to look decent, it'll outlive the truck if done right, and it's actually made for the job at task. Last edited by Longhorn Man; 06-02-2009 at 11:27 PM. |
#15 |
![]() Join Date: Aug 2004
You can get the Edelbrock inlet flare adapter to match the size at the pump. No rubber hose required at all, and like LHM said above, it's cheap.
The most generic flare tool out there will make ok flares for the low pressures in a carb fuel system. Benders are cheap too. There's plenty of other things to spend money on.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 06-02-2009 at 11:34 PM. |
#16 |
Here is a pict of the braided line with anm fittings that we ran from the tank to the pump..everyone does what their budget allows them to do I chosed to go with the best so that I only had to do it one time and so far it has worked out for me...
#17 |
That's about what I have. I would have preferred it exited the sender and took the stock route, but I haven't had any issues with my seat being right up against it.
#18 |
#19 |
![]() Join Date: Jan 2008
I use Russel braided #8AN to the carb. I also bought a new tank and had 2 #10 AN fitting bungs welded in the bottom R/H corner of the tank,one is plugged, but available for a separate nitrous system if desired, the other is for the fuel system.I figure I will never have a fuel starvation problem. I also have an inline Russel filter and ball valve shut off. Greg
#20 |
Do all steel braided hoses come with a rubber core? From looking around it looks like most are rubber hoses that are covered with steel braiding. The one I'm looking to get is good up to 250 degrees. Would that be enough to run up the front side of the block where the steel line was originally? I know Andy said not to use rubber so I'm not sure if steel braided hoses are considered rubber as they have a rubber core?
#21 |
Aeroquip has both internal with rubber and white teflon. The white stuff inside is made to prevent deteriation to certain type synthetics and additives. Personally I used a stainless metal line.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
