1969 GMC backfires
I have a 1969 gmc c25/pick up. I put two cherrybomb glasspacks about 2 weeks ago and the truck backfires when i decelerate from high or medium rpm. It never did before. wats wrong. All it is is the glasspacks and no muffler/exahusts.
1970 Daily Driver
Re: 1969 GMC backfires
Nothing is wrong. Should sound pretty good. My 2 year old son claps and giggles when my truck back fires on deceleration.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
Cool Truck
my truck backfires when I shut it off
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
classic=of recognized value
Mine does that too, pretty cool, huh! My neighbor calls it my Jake Brakes.
Your idle jets are lean. Try turning them out about 1/2 turn. I my young days we used to turn the idle jets way in to get it to do this. It sounded cool. I don't have to be cool anymore.
![]() Join Date: Jan 2007
Sounds like an exhaust leak near the manifold - that can cause a backfire when letting off the gas quickly after accelerating...
Just had my new exhaust installed - it would backfire as loud as can be (scare the crap out of me) when I took my foot off the gas on the highway. |
yip, mine does it when driving with open headers, it winds down real nice like 6000 rpm to 2500 or so, then crackles down to an idle. i think it sounds cool
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
Size Matters
When you close the throttle and the engine is still trying to suck throught the carb, it gets a richer mixture. This rich mixture is not needed since you are not under power so a lot of it is not burned on combustion in the cylinders and finds its way into the exhaust where it finds lots of oxygen in a free flowing exhaust. Heat from exhaust + rich mixture + Oxygen =Result....Ka Booom!
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
Yeah it's unburned fuel igniting inside your new glasspacks. What's your mpg like?
![]() If you have a manual trans and a carb you can turn your engine off on the highway wait a few seconds and then turn the switch back on and listen to that explosion! ![]() |
well how can i stop the backfiring i need help to stop it.plz.
There are alot of things to check. Your spark plugs and wires, distributor cap and rotor. Your carburetor. (what type of carb are you running?)
Do a compression test on each cylinder. If you have one that's low, it's probably not igniting the fuel like it should. |
#13 |
its a 4 barrel edelbrock carb
#14 |
What model? How old is it? Missing any linkages? Does the choke work like it should? Do you know how to adjust it? Is it leaking gas anywhere?
#15 |
First off, a glasspack is a muffler. And when you say no exhausts do you mean no pipes behind the glasspacks? What type of exhaust manifold/headers are you running? How far are the glasspacks from them. What size are your glasspacks/headers/pipes? Provide as much info as you can. What type of heads/intake. How old is the motor? Do you know how to do a compression test?
#16 |
i mean there is no pipes out of the glasspack its just the glasspacks and notin else..
#17 |
I'm sorry razr I don't have enough info to help you much. I will say this, if you put a pipe after those glasspacks they will probably stop the vacum pop.
#18 |
![]() Join Date: Dec 2006
Just fix the leak.Tighten (to recommended torque)or replace doughnut gaskets as needed.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#19 |
Before you play with the pipes, check the timing and vaccum advance. They will backfire when slowing down or pop through the pipes if the timing is late.
But I will agree that it may be going a bit lean when the throttle plate closes. My truck was doing pretty much the same thing and according to my vacuum gage the timing was late but when I swapped carbs I went up several sizes on the jets so I don't actually know which change did the most good but it doesn't pop when I slow down now. |
#20 | |
So putting on glass-packs will change the timing and carb settings?? interesting But I would still just find and fix the leak in the exhaust.
#21 |
How do you know he has an exhaust leak?
#22 | |
Size Matters
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() Last edited by Longhorn321; 06-02-2009 at 10:57 PM. |
#23 | |
#24 |
how do i adjust the carb and how do i fix the exhuast leak ...wat do i have to do
#25 |
If it wasn't backfiring with the other mufflers,forget the carb for now. Make sure the exhaust manifold is torqued to specs.(inside bolts 30,outside 20) -assuming it's a small block with stock manifolds.Then check the dougnut gasket clamps just past the manifold. I can't remember the torque for these,get a manual or just make sure they are very snug.If you see signs of exhaust blowing out of the joint and the nuts are tight,you may have a bad gasket.
