Old 06-01-2009, 08:27 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
fr tire has a bad camber after i switched to disc brakes in front..
okay, when i swapped to discs and diff. front wheels i noticed a slight camber in my front wheel.........my right front wheel to be exact. well i took it to get aligned today, and they couldnt align it because it had too much of a camber, lucklily they didnt charge me anything, i asked the man who worked on it he said i couldnt be the way i put the spring in..im thinkin
#1 spring went in crooked or upside down
#2wheel is bent/warped(truck wheel came off of had slight fender bender)
#3 spindle is warped bent
gonna fool with it tomorow...
watchall think
John
1999 Toyota Tacoma 4x4
Old 06-01-2009, 09:55 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: fr tire has a bad camber after i switched to disc brakes in front..
Wish I had a good answer for you, but know what you mean. When i did mine, my camber was way off. When I had it alligned, they removes all the shims from the pass. side, about 5 of them, and the dr. side only has one left of about 5. I don't know why is was sooooo off. Used same springs, maybe was the way the balljoints fit-more distance between lower control arm and the spindle or it the '85 spindles are actually "taller" but have not seen anyone claim that around here.
Good luck is all i can really offer.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 06-01-2009, 10:55 PM   #3
oldblue1968chevy
you never got it aligned and still running a off camber tire huh...bummer id liek to get it alinged..anybody else
John
Old 06-02-2009, 12:54 AM   #4
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
did you replace the balljoints hen you did the swap?
other than that it may be the spring not aligned, or upside down in the pocket.
if that doesnt fix it it sounds like something may be bent....just a guess.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 06-04-2009, 10:07 AM   #5
grayw0lf
Same problem here. Spring upside down, hadn't thought of that.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-04-2009, 11:01 AM   #6
71tahoe
71tahoe's Avatar
Spring may not be seated but can you put it upside down??
Warped wheel would be easy to detect by jacking up and spinning. It will wobble.
I would lean toward the bent spindle.
71tahoe is offline   Reply With Quote
Old 06-04-2009, 11:57 AM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
Never heard of a spring being upside down.. they are the same on both ends .... just need to be seated correctly in the pocket..... Bent or totally worn out balljoints. surprised the alignment shop didnt check for play in the suspension and say what you needed to have replaced....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-04-2009, 01:51 PM   #8
oldblue1968chevy
hopefully its the spring in crooked or upside down lol, if not that, well HERE WE COME DROP SPINDLES lol
John
Old 06-05-2009, 05:08 PM   #9
70C10Toejam
Hellasick
Slow reply...been busy.
No no...I got it aligned, thus the removal of most of the shims. Aligned real well, until I replace the trailing arm bushings that is...
Old 06-05-2009, 05:43 PM   #10
oldblue1968chevy
you took out the shims or they did...
i may fool with mine in the am and early pm b4 niteride and mudbog...
John
Old 06-05-2009, 08:01 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Fellas, you can't put the spring in upside down. It is pigtailed significantly on the top end. It wouldn't fit into the lower control arm notch if it were upside down.
Old 06-06-2009, 09:58 AM   #12
oldblue1968chevy
i no i realize it now..may take it off and see today....will letcha know...pigtail'd end goes on top correct?
John
Old 06-06-2009, 10:40 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Can you take some pics to help us understand what is going on?
Keith
Convert to disc brakes.
Old 06-06-2009, 11:20 AM   #14
LONGHAIR
The spring itself has absolutely nothing to do with the alignment anyway, so that can't be an issue.....and certainly the alignment place checked for a bent wheel?
Exactly how did you "swap from drums to discs"?
I am going to assume stock spindles because of your mention of "drop spindles" as a potential cure? ...so did you swap the control arms or ball-joints in this process? Entire crossmember?
You stated that the wheels came from a fender-bender, what about your swap parts?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-10-2009, 06:43 PM   #15
70C10Toejam
Hellasick
Alignment shop did...just didn't want to mess with that part.
