Old 01-01-2003, 07:24 PM   #1
DaHateTank
Question Anyone have 8" suspension lifts??
Im considering lifting my Blazer a little more, and Id like to hear some opinions, from those who have this much lift (8") in the suspension...
Did you have to have the front end cut, and twisted to restore the caster (??? - angle thru the ball joints, in the plane parallel to the front-rear axis of the vehicle)
If not, how does the truck drive?? Im concerned about making my Blazer even squirrelier...
thanks
-Marty
DaHateTank is offline   Reply With Quote
Old 01-01-2003, 08:37 PM   #2
Pont
I need another Barley Pop
Pont's Avatar
Yep, 8" suspension lift on mine. Nothing funky about the front end of mine other than some really wicked driveshaft angle. I'm in the process of making a high pinion Dana 44 to fix this problem. Other than that, my truck rides and handles better than stock. Pitch the stock steering and build a crossover setup. If you need anymore info, don't hesitate to PM or email me.
Rob
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-02-2003, 10:31 PM   #3
Slick71
Slick71's Avatar
Hey Pont, Did you have the front springs custom made? If not, who did you buy them through? I've been considering going bigger since the 33's are about worn out.
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 01-03-2003, 01:43 AM   #4
Pont
Pont's Avatar
Hey Slick, the front springs were NOT custom made but the rear springs are. The front springs are SkyJacker Softride and fit 1/2 ton & 3/4 ton 67-72's if I remember correctly. Simple bolt in install without any mods other than extended brake hoses. I think I paid around $280/pair + shipping if that helps. I bought mine through 4 Wheel Parts Wholesalers but I had such a terrible experience with them, I wouldn't recommend them. I'm sure there are other suppliers out there at very competitive prices.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 01-03-2003, 02:17 AM   #5
DaHateTank
Cool
Pont,
Do you have any picas, of your steering setup?
How much tire is under that beastie??
Wheelbase??
Thx
-Marty
PS: I think the 8" springs are up around $320, now.
Old 01-03-2003, 03:50 AM   #6
powermad
Hillbilly Hotrod
My fronts are Burbank HD ones and the rears are Tuff Country easy rides, they have been sitting in the shop for almost a year, I don't have them on yet.
69 K5, .060 over 350/465/205.
powermad is offline   Reply With Quote
Old 01-03-2003, 03:19 PM   #7
Pont
Pont's Avatar
Marty, the wheel base on my truck is stock. The tires are 35 x 14.5 x 15's and my front tires do rub at times. Not because of the height but because of the width and being mounted on a 14" wide rim with minimal offset. I guess it figures that the price of those springs would have gone up since I bought mine in July of 2001.
Here is a link to some pics of my steering setup. The pics are at the end of this thread.
http://67-72chevytrucks.com/vboard/s...threadid=15383
Let me know what you think............
Rob
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 01-03-2003, 07:44 PM   #8
Slick71
Slick71's Avatar
I've got 4" springs in front and 4" blocks with an add-a-leaf in the rear. I'm running 33" Thornbirds on a 12" wheel. If I go to 8" suspension.....what do ya think????? 35's?or Bigger?
Savannah, MO.
Old 01-03-2003, 08:47 PM   #9
powermad
Hillbilly Hotrod
I was gonna with 42's with the 8" lift, but I don't realy care if I have to trim and hack. But now I have changed my mind again and will just do a 4" lift and 39.5"s
The guy the shop with the 72 has a 6" suspension and a 2" body lift and he is running 38's with no troubles.
Old 01-04-2003, 02:28 AM   #10
DaHateTank
Question
Pont,
How'd you weld on that knuckle?? Ive always had bad luck welding cast iron, even pre-heating it. Always seems to crack.
Yours seems to be holding up well, so you musta done something right...
-Marty
Old 01-04-2003, 01:25 PM   #11
Pont
Pont's Avatar
Marty, I had a friend run those welds for me. I don't weld good enough to try that. Next time I see him I'll ask what the trick is to welding on cast iron.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 01-06-2003, 12:59 PM   #12
HIGH724X4
HEY Pont,
You have a very nice looking truck, can you post or email me a bigger pics, so I can check it out? i have a 8" soft ride on my 72 short, and I am in the middle of the frame-off, Taking Forever, Alot ideas, Low on the Money.. Thanks.. Kevin.
72 CHEVY FLEETSIDE 4X4 K10
(SOLD TO JAMIE72,
BUT BLAZER GAL PULLED AWAY WITH IT LOL!!!)
Will Own one Again!!!
1967 CAMARO (PRO-TOURING PROJECT)
Lawrenceburg, Indiana..
AOL IM: kbillcad
HIGH724X4 is offline   Reply With Quote
Old 01-06-2003, 05:19 PM   #13
Pont
Pont's Avatar
Hi Kevin, here are a few larger pics. If you happen to find any of that money your low on, send some my way
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 01-06-2003, 05:20 PM   #14
Pont
Pont's Avatar
2
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 01-06-2003, 05:20 PM   #15
Pont
Pont's Avatar
3
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 01-06-2003, 05:21 PM   #16
Pont
Pont's Avatar
Large version of my Avatar
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 01-06-2003, 06:23 PM   #17
Slick71
Slick71's Avatar
I like that big ol' shortbed more and more, every time I see it. Looking Good Pont!
Savannah, MO.
Old 01-07-2003, 08:51 AM   #18
HIGH724X4
Hey Pont, Thanks for the Pics, Your Truck is Truly Awesome, Just Won A Little Money on my sports bet, But Had To Spend it on A New Cowl Hood, Any Extra, I will send your Way>. HEHE Kevin..
(SOLD TO JAMIE72,
AOL IM: kbillcad
Old 01-07-2003, 01:32 PM   #19
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'm running 6" lift (blocks in back ) with 35 x12.5. I believe the rims are either 8 or 10" wide, but I've never measured them. I haven't had any rubbing (yet). I've heard of guys running Swampers on a similar combo as mine and having rubbing issues. My tires are just a basic all-terrain.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-07-2003, 04:47 PM   #20
Pont
Pont's Avatar
Your Blazer is sharp ( I never get tired of looking at it ) and it's hard to tell from those pics but I'm gonna guess you have 10" rims.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
