Can't wait to retire!!
Rear Leaf Spring problem
Well, I'm finally getting around to working on my Blazer again, but I have a broken leaf in one of my rear leaf spring packs. What would you do? New springs...find one leaf...buy a used set?
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
Re: Rear Leaf Spring problem
Should be able to have a local spring shop replace just that piece, find a shop that does suspension work & you'll be all set.
Might be in your local phone book under 'springs-Automotive Sales & Service' |
#3 | |
![]() Thanks man!
I would replace both sides to keep everyting even. I hate doing things twice so I would buy new. Keep in mind most pre-made rear sporing packs are made to P/U weight specs not Blazers. I run 4" front and 5.5" rear springs and my rig sat level with the hardtop on. Without the hard top I did get a little 'stinkbug' action going but I like that better than the saggy butt syndrome
![]() Good luck ![]() ![]() ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
