Old 06-02-2009, 07:52 AM   #1
The Big Green
Need help: bodydrop, or no bodydrop?
Basically, just like anyone elses bagged, Z'ed, and 4-linked truck, they lay on pinch welds on the rockers. I can only gain like a 1/2in if I cut or fold the pinch welds. Is it worth paying a guy for the labor to do this? I think it's low enough but if the labor wasn't to high then I'd consider of course. It may lay a tad bit more if I did away with pinch welds now. No body is the same, and same with engines. I pretty much dig the welds in the dirt when I lay. How are the guys doing away with the pinch welds on the rockers?
The Big Green is offline   Reply With Quote
Old 06-02-2009, 11:15 AM   #2
68laydout
Junior Member
68laydout's Avatar
Re: Need help: bodydrop, or no bodydrop?
Myself and most just cut the pinch off the bottom of the rocker and lower the body mounts an inch or so. It will lay the bottom of the rocker flat on the ground. I welded some 1/8" thick strap to the bottom of inner/outer rocker for support. Also, the bottom part of the front bed side will still be half an inch or so from the ground. If you want the bed flat out you will have to chop the rockers and raise the floor.
68laydout is offline   Reply With Quote
Old 06-02-2009, 09:10 PM   #3
68laydout
Junior Member
68laydout's Avatar
You can always door it if you are super knar. I would expect 4-6 hours of labor at the very least, unless the cab is already seperated. It's only an inch but all these things are affected. Body mounts, frame horns, firewall trimming, tranny tunnel, steering linkage, brake lines, etc...
Old 06-03-2009, 09:32 AM   #4
The Big Green
Mine has a 2.5 Z, and tranny trunnel has enough room for one inch. That is a lot of work for a inch, but it's all a look thing. Your truck sits good though. I could also do all the body bushings while everythings being moved for the BD.
On a side note, my exhaust was done yesterday and it's way to loud. I have a 4-link, 2-piece driveshaft(swb), and the exhaust can't really be ran past the cab. It's a stock 350, little RV cam, and manifolds. The Magnaflows and 2.5 pipes are dumped at the cab, before, not behind, but you can see it. It's just stupid loud!!! What's on yours and how's it ran?
Old 06-03-2009, 09:43 AM   #5
The Big Green
Almost left this out, carrier bearing is directly behind cab, 2x3 around it for upper 4-link bars, and valves on both sides, 8 valves. No room to go back further with the pipes. Any more stuff and it would be to superfluous.
Old 06-03-2009, 12:40 PM   #6
68laydout
Junior Member
68laydout's Avatar
Still working on the backhalf and have not run the exhaust yet. I'm going to punch some 3.5" holes in the 2x4 crossmember I have right behind the cab and dump right before the axle with one-chamber flows. I would be more worried about the deafening drone you will have than it being loud.
Old 06-03-2009, 06:48 PM   #7
The Big Green
Yea, mine is pretty loud in the cab with the pipes right under me. I think it's also the turndowns being maybe an inch from the pavement when laying out lol.
Old 06-03-2009, 07:09 PM   #8
XXL
Seņor Member
XXL's Avatar
I think it's low enough...
Sounds like you've answered your own question (??)
XXL is offline   Reply With Quote
Old 06-04-2009, 12:24 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Back on topic please.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-04-2009, 03:02 AM   #10
The Big Green
No problem, and thanks.
Old 06-04-2009, 09:50 AM   #11
68laydout
Junior Member
68laydout's Avatar
Get a bid on doing the BD and decide for yourself. I can't see it taking more than 8 hours and $500. So is 1" worth $500 to you? For the exhaust, just move your valves or whatever is keeping it from being run back. Rotate your turndowns 45 degrees outward and extend them to the axle. Also, try to get the mufflers out from under the cab. Doing those three things will make a noticeable difference.
Old 06-04-2009, 10:02 AM   #12
The Big Green
First off $500 isn't bad, if it's that I'd go ahead and do it. I dropped mine the other day and broke the pinch weld on passenger side, back of the cab. It's still there but loose and now has a hole. The hole may have been there but I helped it show up more. As for the mufflers, they will have to stay in place but I will run the pipes on back.
Old 06-04-2009, 10:34 AM   #13
C10Sim
C10Sim's Avatar
I dont want to hijack this thread but Im wanting to lay rockers aswell. If I lower my body mounts would I have to trim pinch welds and would the under floor be hitting the frame?
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
Old 06-04-2009, 10:41 AM   #14
The Big Green
Not sure about the floor, but yes, the mounts are moved down an inch. Most people I talk to just heat and fold the pinch welds insted of cut.
Old 06-04-2009, 10:44 AM   #15
68laydout
Junior Member
68laydout's Avatar
Simply chop the pinch off and lower the body mounts 1" or so. The floor should be 1/4" from the frame at that point. I put some 1/4" rubber bushings between the floor and the frame and they are snug.
Old 06-04-2009, 10:50 AM   #16
C10Sim
C10Sim's Avatar
I not really understanding what your saying here?
Do you mean the rear cab corner section will not be on the ground?
1968 Chevy Pickup
Old 06-04-2009, 11:19 AM   #17
68laydout
Junior Member
68laydout's Avatar
The bottom of the front bed side is not even with the bottom of the rockers. I dont have any pics to show you, but the bottom front portion of the bed is like 1/2" higher than the rocker. I was just stating that the bed would not lay flat after cutting the pinch off. It bugs me the hell out of me, but I'm not cutting more rocker off and raising the floor for 1/2".
I used a cut off wheel to cut the pinch off. Tried a sawzall and the rockers were just too flimsy on mine and bounced around. Not sure about bending them back. That sounds like a lazy way of doing it, but I guess it would work. Mine look clean with the straping and the rockers now have some support and protection.
Old 06-04-2009, 11:27 AM   #18
C10Sim
C10Sim's Avatar
How about bodydroping the bed? Would that work?
1968 Chevy Pickup
Old 06-04-2009, 12:00 PM   #19
68laydout
Junior Member
68laydout's Avatar
Sure, but the body lines will be off unless you drop the cab with it. It's only a half an inch or so, but it is noticeable.
Old 06-04-2009, 12:11 PM   #20
C10Sim
C10Sim's Avatar
Now I see where your coming from...So basically to get the bed on the ground flush you would have to cut the rocker half an inch and do a half an inch bodydrop to cab on the floors?
1968 Chevy Pickup
Old 06-04-2009, 12:41 PM   #21
68laydout
Junior Member
68laydout's Avatar
Yup and then its just the front portion of the bed that lays. The front and rear bumpers are even higher. You'll have to door it if you want it all flat out.
Old 06-04-2009, 12:45 PM   #22
C10Sim
C10Sim's Avatar
Does anybody have a thread that has this process or similar.
1968 Chevy Pickup
