Old 06-02-2009, 09:40 AM   #1
rlcasey75
BoomerSchooner75
not enough vacuum????
does anyone know of a way for me to get more vacuum to my engine. I have a performance camshaft and it is not gettng enough vacuum so when i idle the truck run bad?
rlcasey75 is offline   Reply With Quote
Old 06-02-2009, 10:20 AM   #2
454HO
Re: not enough vacuum????
You don't offer a lot of information.... so how about some basic detailed engine specs, like CID, compression ratio, what heads, what cam, what intake, what carb, etc.
How is your distributor set up? Need initial timing and the total advance and the RPM it is all in by. And are you using vacuum advance? Where is it getting vacuum from and how much timing does it add?
Also what do you have you idle speed set too, and have you tweaked the idle mixture screws for max vacuum? And have you checked for vacuum leaks?
- Greg
454HO is offline   Reply With Quote
Old 06-02-2009, 10:27 AM   #3
rlcasey75
BoomerSchooner75
ok well here is what the truck is doing. When i first start driving it and i come to a stop sign or have to stop and idle the truck wants to die but once i get the temp up above 180 it runs fine unless i floor it than it after the engine revs up it kind of hesitates to catch back up. i also have to let it warmup to 165 before i can shift into gear or else it dies when i shift. the mechanic also said that the cam is a little to big for the engine which is a 350 sb. and i am not sure on all of that info i just bought the truck and i have not have the chance to get inside of her to see what she is packing.
Old 06-02-2009, 10:56 AM   #4
454HO
So then you need to start with the basics.
First thing is to check for obvious problems like unused vacumm ports that are not plugged, rotted vacuum lines that are leaking, bad brake booster, intake manifold gasket sealing issues, etc. Fix all of these issues first.
Next you need to get the ignition sorted out. For a performance cam, you probably need at least 16-18° of initial timing. And most Chevy V8 like 36-38° for total timing. But you will need to experiment and find what your engine likes best. For this you will need a timing light and accurate tachometer. I would also suggest using full manifold vacuum for the vacuum advance instead of ported. This will add additional timing at idle and help smooth it out. If you don't know how to set all this up, there is a FAQ thread in the engine section, here is a direct link to it - Timing FAQ
Once you have the timing sorted out, you can start on tuning the carb. If you do not have a hand-held vacuum guage, I suggest you buy one. You will need it to set the idle mixture, and it will also help with finding the optimum initial timing.
My guess is once you get everything tuned properly you will be okay.
- Greg
Old 06-02-2009, 11:25 AM   #5
rlcasey75
BoomerSchooner75
ok thanks for the replies and help i really appriecate it.
Old 06-02-2009, 06:55 PM   #6
LONGHAIR
There was no mention of transmission either. I am assuming that we're talking automatic by your discription of having ilding problems. If so, this can greatly add to the troubles that you have here. If you don't have the torque converter matched to your cam, it can give you lots of trouble trying to get a reasonable idle....even with all of the other previously mentioned tuning.
If the converter is too "tight", it will be very hard to get it to idle in gear, because of a large drop in RPM. Then if you speed the idle up so that it will stay running in gear, it will be really high in park. There is no way to tune around this. A new higher stall torque convertor is the only fix.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-02-2009, 07:38 PM   #7
rlcasey75
BoomerSchooner75
ok thanks for the info i will look at that too than. it also has th350 turbo tranny.
